Ga door naar hoofdinhoud
HP Officejet J3680 Phone Cord Replacement
Wat je nodig hebt
  1. HP Officejet J3680 Phone Cord Replacement, Unplug phone cord from handset: stap 1, afbeelding 1 van 1
    • Unplug one end of the cord by squeezing the plastic piece and pulling it out from the handset as shown on the left.
  2. HP Officejet J3680 Phone Cord Replacement, Unplug phone cord from back of device: stap 2, afbeelding 1 van 1
    • Turn the device over to see the bottom as shown on the left.
    • First, slide the cord out from under the plastic clip.
    • Then as done in step one, squeeze the plastic piece to remove it from the back of the device.
Conclusie
To reassemble your device, follow these instructions in reverse order. You will know the plastic piece has been inserted correctly if you hear it click into place.
Marisa
206 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 1-1, Duarte Fall 2014 Lid van UMass Dartmouth, Team 1-1, Duarte Fall 2014
UMASSD-DUARTE-F14S1G1
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 253
