Ga door naar hoofdinhoud
HP Officejet J3680 Motherboard Replacement
Wat je nodig hebt
  1. HP Officejet J3680 Motherboard Replacement, Unplug the Device: stap 1, afbeelding 1 van 1
    • Remove the plug from the outlet and from the back of the device
    • Remove the USB Cable from your computer and from the back of the device.
  2. HP Officejet J3680 Motherboard Replacement, Remove Screws From Under the Control Panel: stap 2, afbeelding 1 van 1
    • Using your Torx T10 screwdriver, remove the screws indicated in the picture. Screws are 13mm in length.
  3. HP Officejet J3680 Motherboard Replacement, Remove Screws Underneath the Ink Cartridge Cover: stap 3, afbeelding 1 van 1
  4. HP Officejet J3680 Motherboard Replacement, Remove Screws from Underneath the Phone Panel: stap 4, afbeelding 1 van 1
    • In step 2, you removed the screw from the blue indicated area.
    • Gently pop off the black cover that the phone rests on. Underneath this cover, you will find two more screws.
  5. HP Officejet J3680 Motherboard Replacement, Remove the Screws from the Rear of Device: stap 5, afbeelding 1 van 1
  6. HP Officejet J3680 Motherboard Replacement, Remove Rear Plastic Panel: stap 6, afbeelding 1 van 1
    • Once the rear plastic panel has been removed, you are ready to replace and repair the necessary parts.
  7. HP Officejet J3680 Motherboard Replacement, Remove Plugs from Main Motherboard: stap 7, afbeelding 1 van 1
    • Carefully unplug all of the plugs that are connected to the main motherboard indicating in the picture.
  8. HP Officejet J3680 Motherboard Replacement, Remove Screws: stap 8, afbeelding 1 van 1
    • Using your Torx t10 screwdriver, remove the 4 screws that hold the main motherboard to the device. Screws are 13mm in length.
    • Once removed, the main motherboard will be free from the device. You will notice that on the lefthand side, three of the screws hold down green wires. Make sure when replacing the motherboard that you screw these back into place.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Evan
388 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 1-1, Duarte Fall 2014 Lid van UMass Dartmouth, Team 1-1, Duarte Fall 2014
UMASSD-DUARTE-F14S1G1
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 462
