Ga door naar hoofdinhoud
HP OfficeJet 4650 Paper Tray Replacement
Wat je nodig hebt
  1. HP OfficeJet 4650 Paper Tray Replacement, Paper Tray: stap 1, afbeelding 1 van 2 HP OfficeJet 4650 Paper Tray Replacement, Paper Tray: stap 1, afbeelding 2 van 2
    • Use two hands to carefully flip the printer upside down.
    • Remove the ten 14mm screws by using a 2.0 mm hex screwdriver and turning the screws counterclockwise.
  2. HP OfficeJet 4650 Paper Tray Replacement: stap 2, afbeelding 1 van 2 HP OfficeJet 4650 Paper Tray Replacement: stap 2, afbeelding 2 van 2
    • Lift the left and right side flaps away from the paper tray to remove them.
  3. HP OfficeJet 4650 Paper Tray Replacement: stap 3, afbeelding 1 van 3 HP OfficeJet 4650 Paper Tray Replacement: stap 3, afbeelding 2 van 3 HP OfficeJet 4650 Paper Tray Replacement: stap 3, afbeelding 3 van 3
    • Remove the left spring by grabbing the rubber tips connected to the spring and lifting up.
  4. HP OfficeJet 4650 Paper Tray Replacement: stap 4, afbeelding 1 van 2 HP OfficeJet 4650 Paper Tray Replacement: stap 4, afbeelding 2 van 2
    • Remove the right spring by grabbing the rubber tips connected to the spring and lifting up.
  5. HP OfficeJet 4650 Paper Tray Replacement: stap 5, afbeelding 1 van 1
    • Remove the paper tray by pulling the tray away from the printer.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Stephanie Carpintero
994 Reputatie
5 handleidingen geschreven
Cal Poly, Team S19-G6, Livingston Winter 2018 Lid van Cal Poly, Team S19-G6, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G6
3 Leden
10 handleidingen geschreven
3 opmerkingen
Thank you Stephanie from a clumsy nearly 80yr old who had pulled the tray right out! A very clear guide to a simple job I had not got a clue how to do. Stay virus free and prosper. JG (UK)
John G - Antwoord
Any ideas where a aperson could order a replacement paper tray like this one? (For an HP OfficeJet 4650 model?
suemouthey - Antwoord
I broke the back of the paper tray so my printer continually says to add paper. Where can I buy another paper tray without having to buy a brand new printer?
Jacquie - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 27
Altijd: 4,662
