Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Onderdelen
Geen onderdelen opgegeven.
  1. Deze stap is niet vertaald. Help het te vertalen
    Before beginning, make sure the laptop is completely turned off by pressing the off button and waiting for the screen to turn black.
    • Before beginning, make sure the laptop is completely turned off by pressing the off button and waiting for the screen to turn black.
    • Flip the laptop over so the battery is exposed which will be next to the hinges on the top left and right.
  2. Deze stap is niet vertaald. Help het te vertalen
    Place your thumbs on the slide locks that are next to the hinges and simultaneously push them toward each other to unlock the battery. While still holding onto the slide locks, push the battery away from the laptop with your index fingers. While still holding onto the slide locks, push the battery away from the laptop with your index fingers.
    • Place your thumbs on the slide locks that are next to the hinges and simultaneously push them toward each other to unlock the battery.
    • While still holding onto the slide locks, push the battery away from the laptop with your index fingers.
  3. Deze stap is niet vertaald. Help het te vertalen
    Unscrew the 8 screws on the back cover. There are also two screws in the battery area that you unscrew.
    • Unscrew the 8 screws on the back cover.
    • There are also two screws in the battery area that you unscrew.
  4. Deze stap is niet vertaald. Help het te vertalen
    Use an opening tool and wedge it under the edge and go around the whole laptop to help remove the back cover.
    • Use an opening tool and wedge it under the edge and go around the whole laptop to help remove the back cover.
    • On the side of the laptop, you can see where it can be separated into two parts.
  5. Deze stap is niet vertaald. Help het te vertalen
    This laptop has one RAM. Gently pull out the RAM from the socket. Gently pull out the RAM from the socket.
    • This laptop has one RAM.
    • Gently pull out the RAM from the socket.
Eindstreep
3 andere personen hebben deze handleiding voltooid.
Terrell Bradford
443 Reputatie
3 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 20
Altijd: 643
