Inleiding
If you want to increase your computers memory or are having trouble with speed, the RAM is simple to replace in HP Mini 311.
  1. Lay the laptop  on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case. Lay the laptop  on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case. Lay the laptop  on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
    • Lay the laptop on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
  2. Slide the battery away from the device to remove. Slide the battery away from the device to remove.
    • Slide the battery away from the device to remove.
  3. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  4. With the device still in a bottom side up position, proceed to unscrew the two 4.8mm Phillips 00 screws from the memory shield.
    • With the device still in a bottom side up position, proceed to unscrew the two 4.8mm Phillips 00 screws from the memory shield.
    • The screws will remain in the shied.
  5. Lift the memory shield up and remove from the laptop. Lift the memory shield up and remove from the laptop.
    • Lift the memory shield up and remove from the laptop.
  6. Firmly press on the metal pins located on both sides of the RAM. One side of the RAM will pop up to form a 40 degree angle with the body of the laptop. Simply grab and remove the RAM from the device.
    • Firmly press on the metal pins located on both sides of the RAM.
    • One side of the RAM will pop up to form a 40 degree angle with the body of the laptop.
    • Simply grab and remove the RAM from the device.
Conclusie
Christian Santoyo
369 Reputatie
6 handleidingen geschreven
Cal Poly, Team 20-4, Maness Winter 2013 Lid van Cal Poly, Team 20-4, Maness Winter 2013
CPSU-MANESS-W13S20G4
4 Leden
Één commentaar
4 GB modules are not supported it seems.
You may see posts in the HP Support Forum saying that the Mini 311 will accept a 4 GB module. Possibly this is true for the Pavilion DM, but not the Mini 311.
The service manual says only 2GB or 1 GB are supported.
Other people posted that they tried a 4GB module and it did not work.
rafss - Antwoord
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 4
Afgelopen 30 Dagen: 13
Altijd: 2,571
