Ga door naar hoofdinhoud
HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement
Wat je nodig hebt
  1. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement, Battery and Service Access Cover: stap 1, afbeelding 1 van 1
    • Before beginning, make sure that your computer is turned off and all external power cords are disconnected.
    • Close the laptop and turn it over so that the underside is up and the silver battery bay is facing towards you.
  2. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: stap 2, afbeelding 1 van 3 HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: stap 2, afbeelding 2 van 3 HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: stap 2, afbeelding 3 van 3
    • The battery locking latch is on the bottom right corner; slide it inward to unlock the battery.
    • Slide the battery release latch inwards.
    • Pull the battery towards you to remove it.
  3. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: stap 3, afbeelding 1 van 3 HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: stap 3, afbeelding 2 van 3 HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: stap 3, afbeelding 3 van 3
    • Slide the service access cover release lever to the right.
    • While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover.
  4. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: stap 4, afbeelding 1 van 1
    • Orient the computer as shown in the picture.
  5. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement, Wi-Fi Card (WLAN Module): stap 5, afbeelding 1 van 2 HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement, Wi-Fi Card (WLAN Module): stap 5, afbeelding 2 van 2
    • Locate the Wi-Fi Card (WLAN Module), near the computer's bottom left corner.
  6. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: stap 6, afbeelding 1 van 3 HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: stap 6, afbeelding 2 van 3 HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: stap 6, afbeelding 3 van 3
    • Disconnect the two cables from the Wi-Fi card by gently lifting them away from the card.
    • There should be two black cables, one labeled with a white sticker, connected to the module.
  7. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: stap 7, afbeelding 1 van 1
    • Remove the two 2.0 x 3.0 screws securing the Wi-Fi card using a Phillips #00 screwdriver
    • The card should tilt up away from the laptop at an angle after removing the screws.
  8. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: stap 8, afbeelding 1 van 1
    • Remove the Wi-Fi card by gently pulling it out of its slot at an angle.
    • Potential for device damage: Be sure to pull gently and at an angle away from you. If the card is pulled straight up, there is a chance it could break or bend.
Conclusie
Taylor
116 Reputatie
1 Handleiding geschreven
Cal Poly, Team 3-23, Amido Fall 2012 Lid van Cal Poly, Team 3-23, Amido Fall 2012
CPSU-AMIDO-F12S3G23
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 1,181
