Ga door naar hoofdinhoud
HP Mini 210-2070NR Keyboard Replacement
Wat je nodig hebt
  1. HP Mini 210-2070NR Keyboard Replacement, Battery and Service Access Cover: stap 1, afbeelding 1 van 1
    • Before beginning, make sure that your computer is turned off and all external power cords are disconnected.
    • Close the laptop and turn it over so that the underside is up and the silver battery bay is facing towards you.
  2. HP Mini 210-2070NR Keyboard Replacement: stap 2, afbeelding 1 van 3 HP Mini 210-2070NR Keyboard Replacement: stap 2, afbeelding 2 van 3 HP Mini 210-2070NR Keyboard Replacement: stap 2, afbeelding 3 van 3
    • The battery locking latch is on the bottom right corner; slide it inward to unlock the battery.
    • Slide the battery release latch inwards.
    • Pull the battery towards you to remove it.
  3. HP Mini 210-2070NR Keyboard Replacement: stap 3, afbeelding 1 van 3 HP Mini 210-2070NR Keyboard Replacement: stap 3, afbeelding 2 van 3 HP Mini 210-2070NR Keyboard Replacement: stap 3, afbeelding 3 van 3
    • Slide the service access cover release lever to the right.
    • While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover.
  4. HP Mini 210-2070NR Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Orient the computer as shown in the picture.
  5. HP Mini 210-2070NR Keyboard Replacement, Keyboard: stap 5, afbeelding 1 van 2 HP Mini 210-2070NR Keyboard Replacement, Keyboard: stap 5, afbeelding 2 van 2
    • Using a 00 Phillips screwdriver, unscrew and remove the three 2.0 X 5.0 screws that connect the keyboard to the computer.
    • Each of the screws are labeled with small keyboards next to them.
    • Flip the computer over so that the front is facing you.
  6. HP Mini 210-2070NR Keyboard Replacement: stap 6, afbeelding 1 van 3 HP Mini 210-2070NR Keyboard Replacement: stap 6, afbeelding 2 van 3 HP Mini 210-2070NR Keyboard Replacement: stap 6, afbeelding 3 van 3
    • Open the computer screen as far as possible. It should be able to lay flat on whatever surface you are working on.
    • Pry along the rear edge of the keyboard away from the PC with the plastic opening tool.
    • Once enough of an opening has been established, gently grasp the edge and pull the keyboard towards you.
    • There is a cable connecting the keyboard to the laptop, so do not attempt to fully remove the keyboard yet or you will damage your device.
  7. HP Mini 210-2070NR Keyboard Replacement: stap 7, afbeelding 1 van 2 HP Mini 210-2070NR Keyboard Replacement: stap 7, afbeelding 2 van 2
    • Use your fingernail to flip up the black retaining flap attached to the keyboard ZIF connector.
    • Pull the keyboard cable out of its socket to disconnect it.
  8. HP Mini 210-2070NR Keyboard Replacement: stap 8, afbeelding 1 van 1
    • Remove the keyboard by lifting it away from the computer.
Conclusie
Sean Kuster
91 Reputatie
3 handleidingen geschreven
Cal Poly, Team 3-23, Amido Fall 2012 Lid van Cal Poly, Team 3-23, Amido Fall 2012
CPSU-AMIDO-F12S3G23
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,598
