Ga door naar hoofdinhoud
HP Mini 210-2070NR Battery and Service Access Cover Replacement
  1. HP Mini 210-2070NR Battery and Service Access Cover Replacement, Battery and Service Access Cover: stap 1, afbeelding 1 van 1
    • Before beginning, make sure that your computer is turned off and all external power cords are disconnected.
    • Close the laptop and turn it over so that the underside is up and the silver battery bay is facing towards you.
  2. HP Mini 210-2070NR Battery and Service Access Cover Replacement: stap 2, afbeelding 1 van 3 HP Mini 210-2070NR Battery and Service Access Cover Replacement: stap 2, afbeelding 2 van 3 HP Mini 210-2070NR Battery and Service Access Cover Replacement: stap 2, afbeelding 3 van 3
    • The battery locking latch is on the bottom right corner; slide it inward to unlock the battery.
    • Slide the battery release latch inwards.
    • Pull the battery towards you to remove it.
  3. HP Mini 210-2070NR Battery and Service Access Cover Replacement: stap 3, afbeelding 1 van 3 HP Mini 210-2070NR Battery and Service Access Cover Replacement: stap 3, afbeelding 2 van 3 HP Mini 210-2070NR Battery and Service Access Cover Replacement: stap 3, afbeelding 3 van 3
    • Slide the service access cover release lever to the right.
    • While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover.
  4. HP Mini 210-2070NR Battery and Service Access Cover Replacement: stap 4, afbeelding 1 van 1
    • Orient the computer as shown in the picture.
Conclusie
Sean Kuster
91 Reputatie
3 handleidingen geschreven
Cal Poly, Team 3-23, Amido Fall 2012 Lid van Cal Poly, Team 3-23, Amido Fall 2012
CPSU-AMIDO-F12S3G23
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 1,445
