Ga door naar hoofdinhoud
HP Mini 210-1199DX Wireless Card Replacement
Wat je nodig hebt
  1. HP Mini 210-1199DX Wireless Card Replacement, Battery: stap 1, afbeelding 1 van 2 HP Mini 210-1199DX Wireless Card Replacement, Battery: stap 1, afbeelding 2 van 2
    • Unplug the netbook.
    • Secure the netbook in a upright position.
    • Slide the plastic battery latch that secures it into the netbook.
    • Keep thumb secure on the right tab as you begin to remove the battery.
  2. HP Mini 210-1199DX Wireless Card Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery from the device.
  3. HP Mini 210-1199DX Wireless Card Replacement, Bottom Cover: stap 3, afbeelding 1 van 1
    • Press down on the two orange buttons to release.
    • If the case does not pop off, begin to use Spudger to pry the case off the back.
  4. HP Mini 210-1199DX Wireless Card Replacement: stap 4, afbeelding 1 van 3 HP Mini 210-1199DX Wireless Card Replacement: stap 4, afbeelding 2 van 3 HP Mini 210-1199DX Wireless Card Replacement: stap 4, afbeelding 3 van 3
    • Place the spudger on corners and openings in order to begin removal of the back.
    • Continue this on all corner until the case comes fully off of the back.
  5. HP Mini 210-1199DX Wireless Card Replacement: stap 5, afbeelding 1 van 1
    • Pull the case off of the device
  6. HP Mini 210-1199DX Wireless Card Replacement, Wireless Card: stap 6, afbeelding 1 van 1
    • Locate the Wireless Card.
  7. HP Mini 210-1199DX Wireless Card Replacement: stap 7, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • With fingers or tweezers, carefully pull the black and white wire connectors from their sockets and move them to the side.
  8. HP Mini 210-1199DX Wireless Card Replacement: stap 8, afbeelding 1 van 2 HP Mini 210-1199DX Wireless Card Replacement: stap 8, afbeelding 2 van 2
    • With a Phillip's Screwdriver, firmly but slowly remove the two screws from the top of the wireless card.
    • Be careful not to strip the nail head.
  9. HP Mini 210-1199DX Wireless Card Replacement: stap 9, afbeelding 1 van 1
    • Pull the wireless card out.
Conclusie
Phillip Winston
655 Reputatie
6 handleidingen geschreven
Texas Tech, Team S46-G3, Bennett Spring 2017 Lid van Texas Tech, Team S46-G3, Bennett Spring 2017
TTU-BENNETT-S17S46G3
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 475
