Ga door naar hoofdinhoud
HP Mini 210-1199DX Keyboard Key Replacement
Wat je nodig hebt
  1. HP Mini 210-1199DX Keyboard Key Replacement, Keyboard pieces: stap 1, afbeelding 1 van 1
    • Locate the broken key(s) and make sure there's nothing blocking it or jammed in the slots. Insert the key into the key slot.
  2. HP Mini 210-1199DX Keyboard Key Replacement: stap 2, afbeelding 1 van 1
    • Take a clean cotton swab and make sure to clean out both the key itself alone with the key slot. Remove anything that may be jamming or interfering with the key.
  3. HP Mini 210-1199DX Keyboard Key Replacement: stap 3, afbeelding 1 van 1
    • With the key slot clear, press the key into the slot firmly. Upon hearing a click press it a few times to confirm that it is fully attached.
Conclusie
Phillip Winston
655 Reputatie
6 handleidingen geschreven
Texas Tech, Team S46-G3, Bennett Spring 2017 Lid van Texas Tech, Team S46-G3, Bennett Spring 2017
TTU-BENNETT-S17S46G3
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 10
Altijd: 460
