Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Hold the netbook top-side down with the lid closed.
Slide the plastic battery release latches towards the lock symbols.
Turn the netbook to view its edge.
Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
Pop out the two gold connectors from the antenna wires on top of the WiFi card using a plastic opening tool. This will allow you to dislodge the WiFi card from the rest of the netbook.
Remove the two 3.9 mm screws on top of the WiFi card using the Phillips #00 screwdriver.
Gently pull the WiFi card out of its slot. Be sure to pull the card up and out of the slot towards you.
Één andere persoon heeft deze handleiding voltooid.
