Ga door naar hoofdinhoud
HP Mini 210 WiFi Card Replacement
Wat je nodig hebt
  1. HP Mini 210 WiFi Card Replacement, Battery: stap 1, afbeelding 1 van 2 HP Mini 210 WiFi Card Replacement, Battery: stap 1, afbeelding 2 van 2
    • Turn off and unplug the netbook before replacing the battery.
    • Hold the netbook top-side down with the lid closed.
    • Slide the plastic battery release latches towards the lock symbols.
    • The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
  2. HP Mini 210 WiFi Card Replacement: stap 2, afbeelding 1 van 1
    • Slide the battery out from the netbook.
  3. HP Mini 210 WiFi Card Replacement, Disassembling HP Mini 210 Back Case: stap 3, afbeelding 1 van 1
    • Turn the netbook to view its edge.
    • Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
  4. HP Mini 210 WiFi Card Replacement: stap 4, afbeelding 1 van 1
    • If the back case does not separate from the netbook easily, use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
  5. HP Mini 210 WiFi Card Replacement: stap 5, afbeelding 1 van 1
    • Pull the back case off from the front edge.
  6. HP Mini 210 WiFi Card Replacement, WiFi Card: stap 6, afbeelding 1 van 1
    • Pop out the two gold connectors from the antenna wires on top of the WiFi card using a plastic opening tool. This will allow you to dislodge the WiFi card from the rest of the netbook.
  7. HP Mini 210 WiFi Card Replacement: stap 7, afbeelding 1 van 1
    • Remove the two 3.9 mm screws on top of the WiFi card using the Phillips #00 screwdriver.
  8. HP Mini 210 WiFi Card Replacement: stap 8, afbeelding 1 van 1
    • Gently pull the WiFi card out of its slot. Be sure to pull the card up and out of the slot towards you.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Heather Freed
723 Reputatie
8 handleidingen geschreven
Cal Poly, Team 9-17, Amido Fall 2012 Lid van Cal Poly, Team 9-17, Amido Fall 2012
CPSU-AMIDO-F12S9G17
3 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 38
Altijd: 5,752
