Inleiding
If the system clock or the BIOS (Basic Input/Output System) settings reset when the netbook is turned off, the CMOS (Complementary Metal-Oxide Semiconductor) battery may need to be replaced.
The CMOS battery should be replaced with a 3-volt 2032-size coin battery.
Wat je nodig hebt
Hold the netbook top-side down with the lid closed.
Slide the plastic battery release latches towards the lock symbols.
Turn the netbook to view its edge.
Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
Cut one side of the black adhesive ribbon on top of the CMOS battery with a utility blade.
8 andere personen hebben deze handleiding voltooid.
2 opmerkingen
after need CMOS reset. Screen is black. Is there an easy way on my HP Mini 210?
