Inleiding
If the keys on your keyboard are unresponsive, you might need to replace the keyboard itself. This guide will show you the steps for replacing your HP Mini 110's keyboard.
Wat je nodig hebt
With the bottom of the HP Mini facing up, slide both switches inward towards each other.
Remove the three 4.0 mm screws with the keyboard indicator next to them using a Phillips #1 screw driver.
Bijna klaar!
Conclusie
