Ga door naar hoofdinhoud
Onderdelen
Geen onderdelen opgegeven.
    • Completely turn off the laptop before trying to remove the battery.
    • Turn the laptop upside down, and find the sliding tabs located on the battery.
    • Slide both tabs in an inward direction then slide the battery away from the laptop
  1. Android Fix Kits
    A new screen or battery is one kit away.
    Nu winkelen
    Android Fix Kits
    Nu winkelen
  2. Slightly tilt the screen downward. The screen is attached by internal clips and adhesive, which means that some force will be necessary for this step. Use the plastic opening tool to force the screen bezel from the screen.
    • Slightly tilt the screen downward.
    • The screen is attached by internal clips and adhesive, which means that some force will be necessary for this step.
    • Use the plastic opening tool to force the screen bezel from the screen.
    • Locate the eight silver 2.9mm screws attaching the screen to the lid.
    • Using a PH1 philips head screwdriver detach the screws.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
aarondcollege
1.270 Reputatie
10 handleidingen geschreven
USF Tampa, Team 2-4, Cagle Fall 2016 Lid van USF Tampa, Team 2-4, Cagle Fall 2016
USFT-CAGLE-F16S2G4
5 Leden
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 8
Altijd: 211
