Ga door naar hoofdinhoud
HP Mini 110-3131dx Keyboard Replacement
Wat je nodig hebt
    • Power off the laptop before trying to remove the battery.
    • Turn the laptop upside down, and locate the sliding tabs on the battery.
    • Slide both tabs in an inward direction, then slide the battery away from the laptop.
  1. HP Mini 110-3131dx Keyboard Replacement, Back Cover: stap 2, afbeelding 1 van 2 HP Mini 110-3131dx Keyboard Replacement, Back Cover: stap 2, afbeelding 2 van 2
    • To remove the bottom cover pull the orange tab to the right until it clicks.
    • Carefully disconnect the clips as you lift the bottom cover.
  2. HP Mini 110-3131dx Keyboard Replacement, Keyboard: stap 3, afbeelding 1 van 1
    • Remove the three black screws marked by the keyboard symbol using a Phillips #1 screwdriver.
  3. HP Mini 110-3131dx Keyboard Replacement: stap 4, afbeelding 1 van 3 HP Mini 110-3131dx Keyboard Replacement: stap 4, afbeelding 2 van 3 HP Mini 110-3131dx Keyboard Replacement: stap 4, afbeelding 3 van 3
    • Turn the laptop upright and open it.
    • Disconnect the clips located around the perimeter of the keyboard.
    • Slide the iFixit opening tool between the top edge of the keyboard and the plastic bezel.
    • Start either above the esc key or the delete key.
    • Pull the keyboard with your fingers until it comes out on both sides.
    • Be careful not to pull the keyboard out too fast. There is a fragile ribbon cable that attaches to the motherboard behind the keyboard.
  4. HP Mini 110-3131dx Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Tilt the keyboard toward you to reveal the ribbon cable.
    • Lift up the black tab on top of the keyboard ribbon cable to release the ribbon cable.
    • Pull the ribbon cable out of its container.
Conclusie
To install a different keyboard, follow these instructions in reverse order.
aarondcollege
1.312 Reputatie
10 handleidingen geschreven
USF Tampa, Team 2-4, Cagle Fall 2016 Lid van USF Tampa, Team 2-4, Cagle Fall 2016
USFT-CAGLE-F16S2G4
5 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 2,230
