Ga door naar hoofdinhoud
HP Mini 110-3131dx Hard Drive Replacement
Wat je nodig hebt
    • Power off the laptop before trying to remove the battery.
    • Turn the laptop upside down, and locate the sliding tabs on the battery.
    • Slide both tabs in an inward direction, then slide the battery away from the laptop.
  1. HP Mini 110-3131dx Hard Drive Replacement, Back Cover: stap 2, afbeelding 1 van 2 HP Mini 110-3131dx Hard Drive Replacement, Back Cover: stap 2, afbeelding 2 van 2
    • To remove the bottom cover pull the orange tab to the right until it clicks.
    • Carefully disconnect the clips as you lift the bottom cover.
  2. HP Mini 110-3131dx Hard Drive Replacement, Hard Drive: stap 3, afbeelding 1 van 1
    • Remove the four screws holding down the hard drive using a Phillips #1 screwdriver.
  3. HP Mini 110-3131dx Hard Drive Replacement: stap 4, afbeelding 1 van 2 HP Mini 110-3131dx Hard Drive Replacement: stap 4, afbeelding 2 van 2
    • Lift the black flap covering the hard drive then slide it towards the left using the orange tab until it's released from its receptacle.
    • Pull the hard drive out of the laptop.
    • Put the hard drive in an anti-static bag to decrease the likelihood of harming it with static electricity.
Conclusie
To reinstall a new or old hard drive, follow these instructions in reverse order.
3 andere personen hebben deze handleiding voltooid.
aarondcollege
1.297 Reputatie
10 handleidingen geschreven
USF Tampa, Team 2-4, Cagle Fall 2016 Lid van USF Tampa, Team 2-4, Cagle Fall 2016
USFT-CAGLE-F16S2G4
5 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 11
Altijd: 1,387
