Ga door naar hoofdinhoud
HP Mini 110-1046NR Memory Card Replacement
Wat je nodig hebt
  1. HP Mini 110-1046NR Memory Card Replacement, Battery: stap 1, afbeelding 1 van 3 HP Mini 110-1046NR Memory Card Replacement, Battery: stap 1, afbeelding 2 van 3 HP Mini 110-1046NR Memory Card Replacement, Battery: stap 1, afbeelding 3 van 3
    • Power-off the netbook fully before attempting to remove the battery.
    • Flip your netbook upside down, and locate the sliding tabs near the battery.
    • Slide both tabs inward so that the battery visibly moves away from the case of the computer.
    • Release the tabs and pull the battery out.
  2. HP Mini 110-1046NR Memory Card Replacement, Memory Card Cover: stap 2, afbeelding 1 van 3 HP Mini 110-1046NR Memory Card Replacement, Memory Card Cover: stap 2, afbeelding 2 van 3 HP Mini 110-1046NR Memory Card Replacement, Memory Card Cover: stap 2, afbeelding 3 van 3
    • Flip the netbook over so you are looking at the bottom, and locate the two screws that hold the memory card cover.
    • Next, take a Phillips PH1 screwdriver and unscrew the two screws.
    • These screws will not release from the cover once they are unscrewed.
    • If necessary, use the flat end of the spudger to assist in prying the cover away from the computer.
  3. HP Mini 110-1046NR Memory Card Replacement, Memory Card: stap 3, afbeelding 1 van 3 HP Mini 110-1046NR Memory Card Replacement, Memory Card: stap 3, afbeelding 2 van 3 HP Mini 110-1046NR Memory Card Replacement, Memory Card: stap 3, afbeelding 3 van 3
    • Carefully push the clips to the side, away from the memory card.
    • Note: The memory module is spring-loaded and will pop out when the clips are detatched.
    • Slide the memory card straight out, holding it as shown to avoid getting skin oils on the electrical contacts.
Conclusie
Jared Cooper
649 Reputatie
5 handleidingen geschreven
Clemson, Team 14-1, Benson Fall 2013 Lid van Clemson, Team 14-1, Benson Fall 2013
CLEM-BENSON-F13S14G1
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 1,290
