Ga door naar hoofdinhoud
HP Mini 110-1046NR Battery Replacement
  1. HP Mini 110-1046NR Battery Replacement, Battery: stap 1, afbeelding 1 van 3 HP Mini 110-1046NR Battery Replacement, Battery: stap 1, afbeelding 2 van 3 HP Mini 110-1046NR Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Power-off the netbook fully before attempting to remove the battery.
    • Flip your netbook upside down, and locate the sliding tabs near the battery.
    • Slide both tabs inward so that the battery visibly moves away from the case of the computer.
    • Release the tabs and pull the battery out.
Conclusie
To install a new battery or re-install the one you removed, simply press it into the slot until both tabs snap back to their outward-most position
Amos Hine
1.275 Reputatie
7 handleidingen geschreven
Clemson, Team 14-1, Benson Fall 2013 Lid van Clemson, Team 14-1, Benson Fall 2013
CLEM-BENSON-F13S14G1
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 3,787
