Ga door naar hoofdinhoud
HP Mini 1000 Keyboard Replacement
Wat je nodig hebt
  1. HP Mini 1000 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 2 HP Mini 1000 Keyboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • With the case closed, place the Mini 1000 top-side down on a flat surface.
    • Push both of the battery release latches toward each other.
  2. HP Mini 1000 Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Lift the battery out of the Mini 1000 from the edge closest to the release latches.
  3. HP Mini 1000 Keyboard Replacement, Keyboard: stap 3, afbeelding 1 van 1
    • Remove the following two screws:
    • One 6 mm Phillips screw
    • One 4 mm Phillips screw
  4. HP Mini 1000 Keyboard Replacement: stap 4, afbeelding 1 van 3 HP Mini 1000 Keyboard Replacement: stap 4, afbeelding 2 van 3 HP Mini 1000 Keyboard Replacement: stap 4, afbeelding 3 van 3
    • To facilitate the removal of the keyboard, it is recommended to push the keyboard outwards with one hand through the opening (highlighted in the third picture) located on the backside of the Mini 1000.
    • While pushing through the opening with one hand, grasp the left upper edge with the other hand and slightly pull the keyboard towards you.
    • Once an opening has been established, grasp the keyboard and slowly lift it upwards along the upper perimeter of the top edge.
  5. HP Mini 1000 Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Lift the keyboard out of the upper case, minding the cable that is still connecting it to the motherboard.
  6. HP Mini 1000 Keyboard Replacement: stap 6, afbeelding 1 van 1
    • Use your fingernail or the flat end of a spudger to flip up the retaining flap on the keyboard cable ZIF socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the cable out of its socket and remove the keyboard.
Conclusie
5 andere personen hebben deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 14
Altijd: 9,740
