Ga door naar hoofdinhoud
HP Media Center 876x Optical Drive Replacement
Wat je nodig hebt
  1. HP Media Center 876x Optical Drive Replacement, Side Panel: stap 1, afbeelding 1 van 2 HP Media Center 876x Optical Drive Replacement, Side Panel: stap 1, afbeelding 2 van 2
    • Remove the two (9 mm) hand screws on the back panel.
  2. HP Media Center 876x Optical Drive Replacement: stap 2, afbeelding 1 van 3 HP Media Center 876x Optical Drive Replacement: stap 2, afbeelding 2 van 3 HP Media Center 876x Optical Drive Replacement: stap 2, afbeelding 3 van 3
    • Place the tower on its side.
    • Slide the side panel horizontally to detach, and pull upward to remove.
  3. HP Media Center 876x Optical Drive Replacement, Front Cover: stap 3, afbeelding 1 van 2 HP Media Center 876x Optical Drive Replacement, Front Cover: stap 3, afbeelding 2 van 2
    • Orient the tower vertically.
    • Using the #0 Phillips head screwdriver, unscrew and remove the two (5 mm) screws that fasten the remaining side panel to the tower.
    • Slide the side panel out of its notches, and pull it gently off of the tower.
  4. HP Media Center 876x Optical Drive Replacement: stap 4, afbeelding 1 van 1
    • Gently move the tower so that it is in the horizontal orientation.
    • Press down the black tabs (proximal to you) that fasten the front panel to the tower.
    • Press down on the distal, black tabs (symmetric with respect to the previous tabs).
    • Pull front panel forward slightly.
  5. HP Media Center 876x Optical Drive Replacement: stap 5, afbeelding 1 van 2 HP Media Center 876x Optical Drive Replacement: stap 5, afbeelding 2 van 2
    • The front panel will come off in a hinge-like fashion, exposing the drives underneath.
  6. HP Media Center 876x Optical Drive Replacement, Optical Drive: stap 6, afbeelding 1 van 3 HP Media Center 876x Optical Drive Replacement, Optical Drive: stap 6, afbeelding 2 van 3 HP Media Center 876x Optical Drive Replacement, Optical Drive: stap 6, afbeelding 3 van 3
    • Identify the optical drive.
    • Pull the molex connectors out of the posterior end of the optical drive.
  7. HP Media Center 876x Optical Drive Replacement: stap 7, afbeelding 1 van 3 HP Media Center 876x Optical Drive Replacement: stap 7, afbeelding 2 van 3 HP Media Center 876x Optical Drive Replacement: stap 7, afbeelding 3 van 3
    • Pull the ribbon cable out of the back of the optical drive.
  8. HP Media Center 876x Optical Drive Replacement: stap 8, afbeelding 1 van 3 HP Media Center 876x Optical Drive Replacement: stap 8, afbeelding 2 van 3 HP Media Center 876x Optical Drive Replacement: stap 8, afbeelding 3 van 3
    • Using the Phillips #0 screwdriver, remove the two 5 mm screws that fasten the optical drive into its port.
    • Gently pull the optical drive through the front cavity.
  9. HP Media Center 876x Optical Drive Replacement: stap 9, afbeelding 1 van 2 HP Media Center 876x Optical Drive Replacement: stap 9, afbeelding 2 van 2
    • Remove the optical drive completely from its port.
Conclusie
Balakrishnan Pillai
1.003 Reputatie
8 handleidingen geschreven
Clemson, Team 6-1, Benson Spring 2014 Lid van Clemson, Team 6-1, Benson Spring 2014
CLEM-BENSON-S14S6G1
3 Leden
15 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 12
Altijd: 397
