Ga door naar hoofdinhoud
HP Laserjet Pro 200 Color MFP Power Button Replacement
Wat je nodig hebt
  1. HP Laserjet Pro 200 Color MFP Power Button Replacement, Power Button: stap 1, afbeelding 1 van 2 HP Laserjet Pro 200 Color MFP Power Button Replacement, Power Button: stap 1, afbeelding 2 van 2
    • Turn the printer so that the front is facing to your left.
    • Flip the printer so that it is laying with its left side facing down and the bottom facing you.
  2. HP Laserjet Pro 200 Color MFP Power Button Replacement: stap 2, afbeelding 1 van 1
    • Use a #2 Phillips head screwdriver to unscrew the 8mm screw on the top edge of the printer.
  3. HP Laserjet Pro 200 Color MFP Power Button Replacement: stap 3, afbeelding 1 van 3 HP Laserjet Pro 200 Color MFP Power Button Replacement: stap 3, afbeelding 2 van 3 HP Laserjet Pro 200 Color MFP Power Button Replacement: stap 3, afbeelding 3 van 3
    • There are three tabs along the back right corner of the printer underneath the panel (location is displayed in the second picture).
    • Use a flathead screwdriver to depress the tabs while lightly pulling the panel towards you.
    • Begin with the upmost tab and move your way down, individually depressing the tabs.
    • Pull the panel towards you and remove it from the printer.
  4. HP Laserjet Pro 200 Color MFP Power Button Replacement: stap 4, afbeelding 1 van 2 HP Laserjet Pro 200 Color MFP Power Button Replacement: stap 4, afbeelding 2 van 2
    • Turn the printer so that you are facing the open side with the power button chord.
    • Carefully remove this cord.
  5. HP Laserjet Pro 200 Color MFP Power Button Replacement: stap 5, afbeelding 1 van 3 HP Laserjet Pro 200 Color MFP Power Button Replacement: stap 5, afbeelding 2 van 3 HP Laserjet Pro 200 Color MFP Power Button Replacement: stap 5, afbeelding 3 van 3
    • There is a cover that protects the electronics within the power button.
    • Remove it by pinching the two tabs on the cover.
    • Pull it outward from the printer.
  6. HP Laserjet Pro 200 Color MFP Power Button Replacement: stap 6, afbeelding 1 van 1
    • A tension spring in the form of a bent wire is used to hold the assembly in the printer.
    • In order to remove the spring completely, begin by removing the right end of the wire from it's slot above the power button with a metal spudger.
  7. HP Laserjet Pro 200 Color MFP Power Button Replacement: stap 7, afbeelding 1 van 1
    • Unclip the left side of the wire from printer by applying upwards pressure along the edge of the wire.
    • This step can be done with either your fingers or a prying tool of your choosing.
  8. HP Laserjet Pro 200 Color MFP Power Button Replacement: stap 8, afbeelding 1 van 3 HP Laserjet Pro 200 Color MFP Power Button Replacement: stap 8, afbeelding 2 van 3 HP Laserjet Pro 200 Color MFP Power Button Replacement: stap 8, afbeelding 3 van 3
    • Grab the wire and hold it firmly with two fingers.
    • Pull it directly upwards.
    • Wiggle it until it is fully removed from the printer.
  9. HP Laserjet Pro 200 Color MFP Power Button Replacement: stap 9, afbeelding 1 van 1
    • Pull the power button board directly towards you, until both the board and the wire are fully clear of the printer.
Conclusie
To reassemble your device, follow the instructions in reverse order.
Kendall Gentzen
999 Reputatie
5 handleidingen geschreven
Cal Poly, Team S9-G14, Maness Spring 2019 Lid van Cal Poly, Team S9-G14, Maness Spring 2019
CPSU-MANESS-S19S9G14
4 Leden
11 handleidingen geschreven
Één opmerking
super tuto
avez vous un tuto similaire pour le remplacement de la carte d'alimentation grillée par la foudre ?
philippe juge - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 24
Altijd: 1,983
