Ga door naar hoofdinhoud
HP HDX 16-1160US Wifi Card Replacement
Wat je nodig hebt
  1. HP HDX 16-1160US Wifi Card Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the device over so that the bottom side is facing up and the battery is facing away from you.
  2. HP HDX 16-1160US Wifi Card Replacement: stap 2, afbeelding 1 van 3 HP HDX 16-1160US Wifi Card Replacement: stap 2, afbeelding 2 van 3 HP HDX 16-1160US Wifi Card Replacement: stap 2, afbeelding 3 van 3
    • Locate the slider under the right side of the battery.
    • Using your thumb, slide it all the way to the left until the front of the battery lifts up.
  3. HP HDX 16-1160US Wifi Card Replacement: stap 3, afbeelding 1 van 1
    • With your thumb still holding the slider to the left, use the opposite hand to lift the battery out, removing it from the computer.
  4. HP HDX 16-1160US Wifi Card Replacement, Wifi Card: stap 4, afbeelding 1 van 2 HP HDX 16-1160US Wifi Card Replacement, Wifi Card: stap 4, afbeelding 2 van 2
    • Use the Phillips #1 Screw Driver to unscrew the 6mm screw from the Wi-Fi Card Panel.
    • The 6mm screw will remain in the Wi-Fi card panel and will not fall out.
    • Lift off the Wi-Fi card panel off using the opposite hand.
  5. HP HDX 16-1160US Wifi Card Replacement: stap 5, afbeelding 1 van 2 HP HDX 16-1160US Wifi Card Replacement: stap 5, afbeelding 2 van 2
    • Remove the gray and black wires by gently pulling up on them so that they "unsnap" from the Wi-Fi card.
  6. HP HDX 16-1160US Wifi Card Replacement: stap 6, afbeelding 1 van 1
    • Remove the two 4mm screws with the Phillips #1 screw driver.
  7. HP HDX 16-1160US Wifi Card Replacement: stap 7, afbeelding 1 van 1
    • Carefully use the plastic opening tools to lift the Wi-Fi card up on the left side.
    • Using the opposite hand, pull the Wi-Fi card to the left.
    • Do not lift the Wi-Fi card straight up, this will damage or break the Wi-Fi card.
Conclusie
Marshall Reid
527 Reputatie
3 handleidingen geschreven
Cal Poly, Team 12-38, Maness Spring 2014 Lid van Cal Poly, Team 12-38, Maness Spring 2014
CPSU-MANESS-S14S12G38
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 1,154
