Ga door naar hoofdinhoud
Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
HP HDX 16-1160US DVD Drive Replacement
Wat je nodig hebt
  1. HP HDX 16-1160US DVD Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the device over so that the bottom side is facing up and the battery is facing away from you.
  2. HP HDX 16-1160US DVD Drive Replacement: stap 2, afbeelding 1 van 3 HP HDX 16-1160US DVD Drive Replacement: stap 2, afbeelding 2 van 3 HP HDX 16-1160US DVD Drive Replacement: stap 2, afbeelding 3 van 3
    • Locate the slider under the right side of the battery.
    • Using your thumb, slide it all the way to the left until the front of the battery lifts up.
  3. HP HDX 16-1160US DVD Drive Replacement: stap 3, afbeelding 1 van 1
    • With your thumb still holding the slider to the left, use the opposite hand to lift the battery out, removing it from the computer.
  4. HP HDX 16-1160US DVD Drive Replacement, Keyboard: stap 4, afbeelding 1 van 1
    • Remove the three 4mm screws using Phillips #1 screw driver.
    • Remove the four 6mm screws using Phillips #1 screw driver.
    • Remove the two 3mm screws using Phillips #1 screw driver.
  5. HP HDX 16-1160US DVD Drive Replacement: stap 5, afbeelding 1 van 1
    • Using your fingers, pry off the speaker cover.
  6. HP HDX 16-1160US DVD Drive Replacement: stap 6, afbeelding 1 van 3 HP HDX 16-1160US DVD Drive Replacement: stap 6, afbeelding 2 van 3 HP HDX 16-1160US DVD Drive Replacement: stap 6, afbeelding 3 van 3
    • Use the plastic opener to pry up the chrome keyboard cover from the lab top itself. Carefully work around the edges by prying each snap individually.
    • Remove the chrome keyboard cover.
    • Be careful not to pull the chrome cover completely off because there is a black strip connecting it to the laptop itself.
  7. HP HDX 16-1160US DVD Drive Replacement: stap 7, afbeelding 1 van 3 HP HDX 16-1160US DVD Drive Replacement: stap 7, afbeelding 2 van 3 HP HDX 16-1160US DVD Drive Replacement: stap 7, afbeelding 3 van 3
    • Locate and remove the two 4mm screws with the Phillips #1 screw driver.
  8. HP HDX 16-1160US DVD Drive Replacement: stap 8, afbeelding 1 van 2 HP HDX 16-1160US DVD Drive Replacement: stap 8, afbeelding 2 van 2
    • Using your hands, pull the keyboard out.
    • Do not pull completely off because there is a grey strip connecting it to the laptop itself.
  9. HP HDX 16-1160US DVD Drive Replacement: stap 9, afbeelding 1 van 2 HP HDX 16-1160US DVD Drive Replacement: stap 9, afbeelding 2 van 2
    • Lift the black tab using the plastic opening tool.
    • Gently pull the grey strip out, horizontally way from you. This will release the keyboard from the computer.
  10. HP HDX 16-1160US DVD Drive Replacement, DVD Drive: stap 10, afbeelding 1 van 1
    • Use the Phillips #1 Screw Driver to unscrew the 5mm screw.
  11. HP HDX 16-1160US DVD Drive Replacement: stap 11, afbeelding 1 van 1
    • Flip over the device so that the bottom side is facing up.
    • Use the Phillips #1 Screw Driver to unscrew the 7mm screw near the center of the device.
  12. HP HDX 16-1160US DVD Drive Replacement: stap 12, afbeelding 1 van 1
    • Push down and pull out the DVD on the left side of the device.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Marshall Reid
527 Reputatie
3 handleidingen geschreven
Cal Poly, Team 12-38, Maness Spring 2014 Lid van Cal Poly, Team 12-38, Maness Spring 2014
CPSU-MANESS-S14S12G38
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 1,442
