Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Turn the device over so that the bottom side is facing up and the battery is facing away from you.
Locate the slider under the right side of the battery.
Using your thumb, slide it all the way to the left until the front of the battery lifts up.
With your thumb still holding the slider to the left, use the opposite hand to lift the battery out, removing it from the computer.
