Ga door naar hoofdinhoud
HP G71t-400 Cooling Fan Replacement
Wat je nodig hebt
  1. HP G71t-400 Cooling Fan Replacement, Cooling Fan: stap 1, afbeelding 1 van 3 HP G71t-400 Cooling Fan Replacement, Cooling Fan: stap 1, afbeelding 2 van 3 HP G71t-400 Cooling Fan Replacement, Cooling Fan: stap 1, afbeelding 3 van 3
    • Lay the laptop down so the bottom is facing up.
    • Push the slide button, circled in photo 1, to release the battery.
    • Action in picture 2 shows the direction and release.
    • Tilt the battery back in the direction it popped up in and remove the battery.
    • This ensures there is no power in the system that could potentially short out any components.
  2. HP G71t-400 Cooling Fan Replacement: stap 2, afbeelding 1 van 3 HP G71t-400 Cooling Fan Replacement: stap 2, afbeelding 2 van 3 HP G71t-400 Cooling Fan Replacement: stap 2, afbeelding 3 van 3
    • Remove the circled screws.
    • Remove the cover, exposing the hard drive and RAM.
  3. HP G71t-400 Cooling Fan Replacement: stap 3, afbeelding 1 van 3 HP G71t-400 Cooling Fan Replacement: stap 3, afbeelding 2 van 3 HP G71t-400 Cooling Fan Replacement: stap 3, afbeelding 3 van 3
    • Remove the 2 circled screws.
    • Use your pry to slide the hard drive over. This unplugs it from its connection and allows it to be removed.
    • Remove the hard drive.
  4. HP G71t-400 Cooling Fan Replacement: stap 4, afbeelding 1 van 2 HP G71t-400 Cooling Fan Replacement: stap 4, afbeelding 2 van 2
    • Push the silver tabs in to release the RAM.
    • When they pop up from the locked position they may be removed.
    • Remove the circled screws to release the WiFi card and keyboard.
  5. HP G71t-400 Cooling Fan Replacement: stap 5, afbeelding 1 van 3 HP G71t-400 Cooling Fan Replacement: stap 5, afbeelding 2 van 3 HP G71t-400 Cooling Fan Replacement: stap 5, afbeelding 3 van 3
    • Remove the panel, exposing the WiFi card.
    • Remove the circle wire connections, make note to which port they were connected to.
    • Remove the WiFi card.
  6. HP G71t-400 Cooling Fan Replacement: stap 6, afbeelding 1 van 3 HP G71t-400 Cooling Fan Replacement: stap 6, afbeelding 2 van 3 HP G71t-400 Cooling Fan Replacement: stap 6, afbeelding 3 van 3
    • Flip the laptop over and open it now that the keyboard has been unscrewed.
    • Take your pry bar and go around the outer edge of the keyboard. Popping it free from the bezel.
  7. HP G71t-400 Cooling Fan Replacement: stap 7, afbeelding 1 van 3 HP G71t-400 Cooling Fan Replacement: stap 7, afbeelding 2 van 3 HP G71t-400 Cooling Fan Replacement: stap 7, afbeelding 3 van 3
    • Lift the keyboard up.
    • Remove the connections from the keyboard to the motherboard.
    • Remember each attachments position because they will need to be connected again.
  8. HP G71t-400 Cooling Fan Replacement: stap 8, afbeelding 1 van 3 HP G71t-400 Cooling Fan Replacement: stap 8, afbeelding 2 van 3 HP G71t-400 Cooling Fan Replacement: stap 8, afbeelding 3 van 3
    • Remove the circled screws to release the bezel from the faceplate.
  9. HP G71t-400 Cooling Fan Replacement: stap 9, afbeelding 1 van 2 HP G71t-400 Cooling Fan Replacement: stap 9, afbeelding 2 van 2
    • Lift the bezel from the face plate.
    • Disconnect the power connection from the bezel to the motherboard.
  10. HP G71t-400 Cooling Fan Replacement: stap 10, afbeelding 1 van 3 HP G71t-400 Cooling Fan Replacement: stap 10, afbeelding 2 van 3 HP G71t-400 Cooling Fan Replacement: stap 10, afbeelding 3 van 3
    • Remove the two screws side-by-side next to each in the red circle.
    • This will be the last layer to remove before reaching the motherboard.
  11. HP G71t-400 Cooling Fan Replacement: stap 11, afbeelding 1 van 2 HP G71t-400 Cooling Fan Replacement: stap 11, afbeelding 2 van 2
    • Carefully detach the highlighted connections.
    • Remove the motherboard from the device.
  12. HP G71t-400 Cooling Fan Replacement: stap 12, afbeelding 1 van 3 HP G71t-400 Cooling Fan Replacement: stap 12, afbeelding 2 van 3 HP G71t-400 Cooling Fan Replacement: stap 12, afbeelding 3 van 3
    • Remove three screws to detach the cooling fan from the motherboard.
    • Remove the last connection.
Conclusie
Nicholas Castro
711 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team S1-G5, Simcock Spring 2019 Lid van UMass Dartmouth, Team S1-G5, Simcock Spring 2019
UMASSD-SIMCOCK-S19S1G5
2 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 137
