Inleiding
This repair method might be needed when an HP G71t-400 is suffering from poor battery performance. If your device needs a battery replacement and this guide will assist you in doing so. To replace the battery no special skills or tools are required. There is nothing unusual about this repair and it is straightforward.
Lay the laptop down so the bottom is facing up.
Push the slide button, circled in photo 1, to release the battery.
Action in picture 2 shows the direction and release.
Tilt the battery back in the direction it popped up in and remove the battery.
