Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Gereedschap gebruikt in deze stap:Anti-Static Wrist Strap$7.95-
Ground yourself by either touching an unpainted metal surface or by using the Anti-Static wrist strap.
Turn off the computer and remove the charger from the charging port.
Turn the laptop over and slide the battery release catch to the right. The battery will pop up from its slot. Remove the battery using your fingers.
Remove the 6mm screw from the cover above the battery using a Phillips #0 screwdriver.
Pull off the bottom cover to reveal the Wi-Fi card.
Gently remove the 2 cables clips to avoid damage.
Remove the 3mm screw holding the Wi-Fi module using a Phillips #0 screwdriver.
