Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Gereedschap gebruikt in deze stap:Anti-Static Wrist Strap$7.95-
Ground yourself by either touching an unpainted metal surface or by using the Anti-Static wrist strap.
Turn off the computer and remove the charger from the charging port.
Turn the laptop over and slide the battery release catch to the right. The battery will pop up from its slot. Remove it using your fingers.
Use a Phillips #0 screwdriver to remove the four screws from the indicated cover.
Gently lift and remove the cover.
Remove the five 6mm screws with the Phillips #0 screwdriver.
Pry the keyboard off with a spudger. Be careful not to apply too much pressure and damage any components.
Disconnect the clip attaching the keyboard wiring to the motherboard. Lift and remove the keyboard.
