Ga door naar hoofdinhoud
HP G62-234DX Hard Drive Replacement
Wat je nodig hebt
  1. HP G62-234DX Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure the computer is turned off, disconnected from the charger, and on a steady surface.
    • Unlock the battery by sliding the button just below it, to the left.
  2. HP G62-234DX Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • While pushing the lock button to the unlock position, slide the battery out and away from the laptop.
    • When sliding the new battery back into the socket, you'll know it's secure when you hear a click.
  3. HP G62-234DX Hard Drive Replacement, Hard Drive: stap 3, afbeelding 1 van 3 HP G62-234DX Hard Drive Replacement, Hard Drive: stap 3, afbeelding 2 van 3 HP G62-234DX Hard Drive Replacement, Hard Drive: stap 3, afbeelding 3 van 3
    • It Is recommended to remove the RAM panel for easier access when removing the hard drive panel.
    • Use a Phillips #0 screwdriver to remove the two screws securing the hard drive panel on the back of the laptop.
    • Use a spudger to remove hard drive panel and carefully lift it up and out.
  4. HP G62-234DX Hard Drive Replacement: stap 4, afbeelding 1 van 1
    • Pull the hard drive from the SATA connector to remove the hard drive from the laptop.
Conclusie
Cameron Popillo
337 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 5-1, Ramos Spring 2023 Lid van UMass Dartmouth, Team 5-1, Ramos Spring 2023
UMASSD-RAMOS-S23S5G1
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 10
Altijd: 89
