Ga door naar hoofdinhoud
HP G62-223CL Wireless Card Replacement
Wat je nodig hebt
  1. HP G62-223CL Wireless Card Replacement, Battery Removal: stap 1, afbeelding 1 van 2 HP G62-223CL Wireless Card Replacement, Battery Removal: stap 1, afbeelding 2 van 2
    • Removing the battery while the laptop is still on may corrupt your files.
    • Turn the device over to expose the bottom of the device.
    • Slide the battery release all the way to the left.
    • There will be a click and the battery will be released from its compartment.
  2. HP G62-223CL Wireless Card Replacement: stap 2, afbeelding 1 van 1
    • Carefully remove the battery from its compartment.
  3. HP G62-223CL Wireless Card Replacement, Wireless Card: stap 3, afbeelding 1 van 2 HP G62-223CL Wireless Card Replacement, Wireless Card: stap 3, afbeelding 2 van 2
    • Locate three Phillips head retaining screws which secure the compartment.
    • Use a Phillips #0 screwdriver to loosen the retaining screws.
    • Remove the panel covering the compartment.
    • Ground yourself before attempting to touch any components. To ground yourself, touch a conductive metal to eliminate any static buildup in your body, which can damage computer components.
  4. HP G62-223CL Wireless Card Replacement: stap 4, afbeelding 1 van 3 HP G62-223CL Wireless Card Replacement: stap 4, afbeelding 2 van 3 HP G62-223CL Wireless Card Replacement: stap 4, afbeelding 3 van 3
    • Use tweezers to disconnect the gray cable and the black cable from the wireless card.
  5. HP G62-223CL Wireless Card Replacement: stap 5, afbeelding 1 van 1
    • Use a Phillips #0 screwdriver to remove the single 4mm screw from the corner of the wireless card.
  6. HP G62-223CL Wireless Card Replacement: stap 6, afbeelding 1 van 1
    • Carefully lift and pull wireless card. It is removed!
Conclusie
Garret Layton
669 Reputatie
5 handleidingen geschreven
USF Tampa, Team 1-4, Sullivan Winter 2015 Lid van USF Tampa, Team 1-4, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G4
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 1,078
