Ga door naar hoofdinhoud
HP G62-223CL Optical Drive Replacement
Wat je nodig hebt
  1. HP G62-223CL Optical Drive Replacement, Battery Removal: stap 1, afbeelding 1 van 2 HP G62-223CL Optical Drive Replacement, Battery Removal: stap 1, afbeelding 2 van 2
    • Removing the battery while the laptop is still on may corrupt your files.
    • Turn the device over to expose the bottom of the device.
    • Slide the battery release all the way to the left.
    • There will be a click and the battery will be released from its compartment.
  2. HP G62-223CL Optical Drive Replacement: stap 2, afbeelding 1 van 1
    • Carefully remove the battery from its compartment.
  3. HP G62-223CL Optical Drive Replacement, Optical Drive: stap 3, afbeelding 1 van 1
    • Locate two Phillips head retaining screws which secure the hard drive compartment.
    • Use a Phillips #0 screwdriver to loosen the retaining screws.
    • Remove the panel covering the compartment.
    • Ground yourself before attempting to touch any components. To ground yourself, touch a conductive metal to eliminate any static buildup in your body, which can damage computer components.
  4. HP G62-223CL Optical Drive Replacement: stap 4, afbeelding 1 van 1
    • Locate the 6 mm Phillips head screw to the left of the hard drive.
    • Use a Phillips #0 screwdriver to remove the screw.
  5. HP G62-223CL Optical Drive Replacement: stap 5, afbeelding 1 van 2 HP G62-223CL Optical Drive Replacement: stap 5, afbeelding 2 van 2
    • Once the screw is removed, use a plastic opening tool and place it between the body of the computer and the optical drive.
    • Apply enough pressure to loosen the optical drive.
    • The optical drive can then be removed by hand.
Conclusie
Garret Layton
669 Reputatie
5 handleidingen geschreven
USF Tampa, Team 1-4, Sullivan Winter 2015 Lid van USF Tampa, Team 1-4, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G4
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 1,196
