Ga door naar hoofdinhoud
HP G62-144DX Keyboard Replacement
Wat je nodig hebt
  1. HP G62-144DX Keyboard Replacement, Battery: stap 1, afbeelding 1 van 2 HP G62-144DX Keyboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Make sure to turn off the laptop before removing the battery.
    • Slide the lock to the right, located slightly above the battery location.
    • While pulling the lock, pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  2. HP G62-144DX Keyboard Replacement, Keyboard: stap 2, afbeelding 1 van 1
    • Remove the 3 Phillips 2.5x5 screws (closest to the battery slot) and the 2 Phillips 2.5x6.5 screws with a Phillips #1 screwdriver.
    • This screws will have a keyboard symbol inscribed next to them.
  3. HP G62-144DX Keyboard Replacement: stap 3, afbeelding 1 van 3 HP G62-144DX Keyboard Replacement: stap 3, afbeelding 2 van 3 HP G62-144DX Keyboard Replacement: stap 3, afbeelding 3 van 3
    • Use the Phillips # 1 screwdriver to unscrew the 2.5x6 Phillips screws holding the L-shaped back panel.
    • Screws should stay in panel, but come free of the laptop body.
    • Gently use a plastic opening tool to remove the panel.
  4. HP G62-144DX Keyboard Replacement: stap 4, afbeelding 1 van 2 HP G62-144DX Keyboard Replacement: stap 4, afbeelding 2 van 2
    • Unscrew the final Phillips 2.5x5 keyboard screw with a Phillips #1 screwdriver.
  5. HP G62-144DX Keyboard Replacement: stap 5, afbeelding 1 van 2 HP G62-144DX Keyboard Replacement: stap 5, afbeelding 2 van 2
    • Flip the laptop so the top is facing up again and open the cover.
    • Use a metal spudger to pry the keyboard up and pull it back.
    • Be sure to pry up the board itself and not an individual key.
    • This process has the risk of breaking keys.
  6. HP G62-144DX Keyboard Replacement: stap 6, afbeelding 1 van 2 HP G62-144DX Keyboard Replacement: stap 6, afbeelding 2 van 2
    • Pull up the latch that connects the keyboard connector the the motherboard.
Conclusie
Cameron Moran
623 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S4-G8, Julie Fall 2017 Lid van UMass Dartmouth, Team S4-G8, Julie Fall 2017
UMASSD-JULIE-F17S4G8
3 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 613
