Ga door naar hoofdinhoud
HP G62-144DX Hard Drive Replacement
Wat je nodig hebt
  1. HP G62-144DX Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 2 HP G62-144DX Hard Drive Replacement, Battery: stap 1, afbeelding 2 van 2
    • Make sure to turn off the laptop before removing the battery.
    • Slide the lock to the right, located slightly above the battery location.
    • While pulling the lock, pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  2. HP G62-144DX Hard Drive Replacement, Hard Drive: stap 2, afbeelding 1 van 3 HP G62-144DX Hard Drive Replacement, Hard Drive: stap 2, afbeelding 2 van 3 HP G62-144DX Hard Drive Replacement, Hard Drive: stap 2, afbeelding 3 van 3
    • Loosen the 2 Phillips 2.5x6 screws in the rectangular panel with a Phillips #1 screwdriver.
    • The screws will stay in the panel, but come free from the body of the computer.
    • Gently remove the panel with a plastic opening tool.
  3. HP G62-144DX Hard Drive Replacement: stap 3, afbeelding 1 van 3 HP G62-144DX Hard Drive Replacement: stap 3, afbeelding 2 van 3 HP G62-144DX Hard Drive Replacement: stap 3, afbeelding 3 van 3
    • Unscrew the three 3x4 Phillips screws holding the hard drive in with a Phillips #1 screwdriver.
    • Pull the hard drive cable out of the motherboard.
    • Pull the hard drive out of the computer.
Conclusie
Cameron Moran
623 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S4-G8, Julie Fall 2017 Lid van UMass Dartmouth, Team S4-G8, Julie Fall 2017
UMASSD-JULIE-F17S4G8
3 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 335
