Ga door naar hoofdinhoud
HP G62 347NR Keyboard Replacement
Wat je nodig hebt
  1. HP G62 347NR Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Make sure the device is turned off before removing the battery to avoid loss or corruption of files.
    • Turn the device over so the bottom is facing up.
    • Slide the battery release to the left until you hear a click.
    • Once you hear a click, the battery will have been released from the battery compartment.
  2. HP G62 347NR Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery, carefully, from the compartment.
  3. HP G62 347NR Keyboard Replacement: stap 3, afbeelding 1 van 2 HP G62 347NR Keyboard Replacement: stap 3, afbeelding 2 van 2
    • Find the hard drive compartment with two Phillips head screws.
    • Use the PH1 screwdriver to loosen and remove both screws.
    • Gently remove the hard drive compartment.
  4. HP G62 347NR Keyboard Replacement: stap 4, afbeelding 1 van 2 HP G62 347NR Keyboard Replacement: stap 4, afbeelding 2 van 2
    • Locate the three Phillips head screws on the compartment with the wifi and keyboard logos.
    • Using the Phillips #1 screwdriver, remove the three screws.
  5. HP G62 347NR Keyboard Replacement: stap 5, afbeelding 1 van 2 HP G62 347NR Keyboard Replacement: stap 5, afbeelding 2 van 2
    • Locate the two keyboard logos on back of the computer.
    • Find the Phillips head screws in the hole next to the logo.
    • Remove the two screws using a Phillips #1 screwdriver.
  6. HP G62 347NR Keyboard Replacement: stap 6, afbeelding 1 van 2 HP G62 347NR Keyboard Replacement: stap 6, afbeelding 2 van 2
    • In the battery compartment, locate the three keyboard logos.
    • Find the Phillips head screws next to each logo.
    • Remove the three screws using the Phillips #1 screwdriver.
  7. HP G62 347NR Keyboard Replacement: stap 7, afbeelding 1 van 2 HP G62 347NR Keyboard Replacement: stap 7, afbeelding 2 van 2
    • Place the plastic opening tool between the keyboard and the motherboard.
    • Gently pry the entire keyboard up and away from the laptop's motherboard.
    • Once you have part of the keyboard separated, run your fingers around the edge of the keyboard to separate the entire thing.
Conclusie
3 andere personen hebben deze handleiding voltooid.
McKenzi Morris
511 Reputatie
3 handleidingen geschreven
Texas Tech, Team 6-1, Bennett Fall 2016 Lid van Texas Tech, Team 6-1, Bennett Fall 2016
TTU-BENNETT-F16S6G1
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 16
Altijd: 2,766
