Ga door naar hoofdinhoud
HP G62 347NR Battery Replacement
Wat je nodig hebt
  1. HP G62 347NR Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure the device is turned off before removing the battery to avoid loss or corruption of files.
    • Turn the device over so the bottom is facing up.
    • Slide the battery release to the left until you hear a click.
    • Once you hear a click, the battery will have been released from the battery compartment.
  2. HP G62 347NR Battery Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery, carefully, from the compartment.
Conclusie
McKenzi Morris
511 Reputatie
3 handleidingen geschreven
Texas Tech, Team 6-1, Bennett Fall 2016 Lid van Texas Tech, Team 6-1, Bennett Fall 2016
TTU-BENNETT-F16S6G1
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 488
