Ga door naar hoofdinhoud
HP G62 347NR CD/DVD Drive Replacement
Wat je nodig hebt
  1. HP G62 347NR  CD/DVD Drive Replacement, CD/DVD Drive: stap 1, afbeelding 1 van 1
    • Make sure the device is turned off before removing the battery to avoid loss or corruption of files.
    • Turn the device over so the bottom is facing up.
    • Slide the battery release to the left until you hear a click.
    • Once you hear a click, the battery will have been released from the battery compartment.
  2. HP G62 347NR  CD/DVD Drive Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery, carefully, from the compartment.
  3. HP G62 347NR  CD/DVD Drive Replacement: stap 3, afbeelding 1 van 1
    • Find the hard drive compartment with two Phillips head screws.
    • Use the PH1 screwdriver to loosen and remove both screws.
    • Gently remove the hard drive compartment.
  4. HP G62 347NR  CD/DVD Drive Replacement: stap 4, afbeelding 1 van 1
    • On the far left of the hard drive compartment, find the Phillips head screw.
    • Remove the Phillips head screw with the PH1 screwdriver.
  5. HP G62 347NR  CD/DVD Drive Replacement: stap 5, afbeelding 1 van 2 HP G62 347NR  CD/DVD Drive Replacement: stap 5, afbeelding 2 van 2
    • Get the plastic opening tool and place it between the laptop and the CD/DVD drive. Place it toward the center of the drive for maximum support.
    • Carefully pry the CD/DVD drive open.
    • Slide the CD/DVD drive out once it is pried open.
Conclusie
McKenzi Morris
511 Reputatie
3 handleidingen geschreven
Texas Tech, Team 6-1, Bennett Fall 2016 Lid van Texas Tech, Team 6-1, Bennett Fall 2016
TTU-BENNETT-F16S6G1
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 9
Altijd: 548
