Ga door naar hoofdinhoud
HP G60T-600 CTO CD Player Replacement
Wat je nodig hebt
  1. HP G60T-600 CTO CD Player Replacement, Battery: stap 1, afbeelding 1 van 1
    • Failure to remove the battery before performing any replacement guide may result in electric shock.
    • Close your device, then turn it over.
  2. HP G60T-600 CTO CD Player Replacement: stap 2, afbeelding 1 van 2 HP G60T-600 CTO CD Player Replacement: stap 2, afbeelding 2 van 2
    • Place your index finger on the ridged tab.
  3. HP G60T-600 CTO CD Player Replacement: stap 3, afbeelding 1 van 1
    • Apply moderate pressure to the tab and slide it to the right.
    • While the tab is on the right, you should be able to gently slide your battery out of your device.
  4. HP G60T-600 CTO CD Player Replacement, Keyboard: stap 4, afbeelding 1 van 2 HP G60T-600 CTO CD Player Replacement, Keyboard: stap 4, afbeelding 2 van 2
    • Unscrew the following 5mm screws with a #0 Phillips screwdriver.
  5. HP G60T-600 CTO CD Player Replacement: stap 5, afbeelding 1 van 1
    • Turn your laptop over and open it up.
    • Grip your laptop firmly from both sides and use your thumbs to slide the keyboard towards the screen.
  6. HP G60T-600 CTO CD Player Replacement: stap 6, afbeelding 1 van 1
    • Pull up on the top of your keyboard with medium force. It should start to pop out.
    • A plastic opening tool may facilitate this task.
    • Run your hands underneath the edges of the keyboard until it is free from the device.
    • Do not pull hard to take the keyboard out. There is a small connection that needs to be undone.
  7. HP G60T-600 CTO CD Player Replacement: stap 7, afbeelding 1 van 2 HP G60T-600 CTO CD Player Replacement: stap 7, afbeelding 2 van 2
    • Place your thumbs on the two small, white tabs.
    • Push these tabs forward to release the connection and free the keyboard from the device.
  8. HP G60T-600 CTO CD Player Replacement, Power Button Frame: stap 8, afbeelding 1 van 1
    • Similarly to how you remove the keyboard, gently pry a small section of the power button frame up.
  9. HP G60T-600 CTO CD Player Replacement: stap 9, afbeelding 1 van 2 HP G60T-600 CTO CD Player Replacement: stap 9, afbeelding 2 van 2
    • Gently pull the white tab upwards.
    • With similar force, pull the connection out.
    • You are now free to pull the power button frame off of your device.
  10. HP G60T-600 CTO CD Player Replacement: stap 10, afbeelding 1 van 1
    • Unscrew the 5mm screw holding the CD player in place.
  11. HP G60T-600 CTO CD Player Replacement, CD Player: stap 11, afbeelding 1 van 3 HP G60T-600 CTO CD Player Replacement, CD Player: stap 11, afbeelding 2 van 3 HP G60T-600 CTO CD Player Replacement, CD Player: stap 11, afbeelding 3 van 3
    • Slide the CD player case away from the device with medium-hard force, it should come right out.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Dominic DeSantis
748 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team 4-5, Catania Fall 2016 Lid van UMass Dartmouth, Team 4-5, Catania Fall 2016
UMASSD-CATANIA-F16S4G5
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 106
