Ga door naar hoofdinhoud
HP G60-443CL Battery Replacement
Wat je nodig hebt
  1. HP G60-443CL Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Place the laptop upside down where the headphone and auxiliary jack are facing you.
  2. HP G60-443CL Battery Replacement: stap 2, afbeelding 1 van 1
    • In the top left corner, there is a lever that has a small picture of a battery on it. Slide the lever to the left.
  3. HP G60-443CL Battery Replacement: stap 3, afbeelding 1 van 1
    • Once you have slid the lever to the left, the front part of the battery will be released and you should be able to grab the released part of the battery with your thumb.
  4. HP G60-443CL Battery Replacement: stap 4, afbeelding 1 van 1
    • The battery can then be pulled out of its compartment by hand.
Conclusie
Alora Allen
101 Reputatie
1 Handleiding geschreven
Baylor, Team S8-G7, Johnson Fall 2017 Lid van Baylor, Team S8-G7, Johnson Fall 2017
BU-JOHNSON-F17S8G7
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 343
