Ga door naar hoofdinhoud
HP G60 RAM Replacement
Wat je nodig hebt
  1. HP G60 RAM Replacement, Battery: stap 1, afbeelding 1 van 3 HP G60 RAM Replacement, Battery: stap 1, afbeelding 2 van 3 HP G60 RAM Replacement, Battery: stap 1, afbeelding 3 van 3
    • First, you should to remove the battery to avoid electric shocks
    • Slide and unlock the battery, then, lift it
  2. HP G60 RAM Replacement, RAM cover: stap 2, afbeelding 1 van 3 HP G60 RAM Replacement, RAM cover: stap 2, afbeelding 2 van 3 HP G60 RAM Replacement, RAM cover: stap 2, afbeelding 3 van 3
    • Remove the two screws with a not too large screwdriver
    • Now lift the cover, the screws are part of the cover
  3. HP G60 RAM Replacement, Eject RAM: stap 3, afbeelding 1 van 3 HP G60 RAM Replacement, Eject RAM: stap 3, afbeelding 2 van 3 HP G60 RAM Replacement, Eject RAM: stap 3, afbeelding 3 van 3
    • Push the little aluminum locks at the top and the bottom of the ram
    • The memory will lift, then pull it
    • Make this with the another RAM slot
  4. HP G60 RAM Replacement, New RAM: stap 4, afbeelding 1 van 3 HP G60 RAM Replacement, New RAM: stap 4, afbeelding 2 van 3 HP G60 RAM Replacement, New RAM: stap 4, afbeelding 3 van 3
    • The new RAM memory should to be insert in a 45 degrees angle
    • Then, push it and the memory will lock by itself
    • Make this with the second memory
  5. HP G60 RAM Replacement, RAM cover (Again): stap 5, afbeelding 1 van 3 HP G60 RAM Replacement, RAM cover (Again): stap 5, afbeelding 2 van 3 HP G60 RAM Replacement, RAM cover (Again): stap 5, afbeelding 3 van 3
    • Insert the cover from right to left, then, screw it
    • If cover is lifted, press it softly and secure it
Eindstreep
5 andere personen hebben deze handleiding voltooid.
jimenezser
3.899 Reputatie
4 handleidingen geschreven
1Gids Commentaar
Thanks for verifying the RAM replacement and that it was as easy as I thought it was, but that made me a bit nervous, being much more comfortable building desktops as large as my or my customer's budget would allow!
Take 'em out, put new ones back in. As a technical writer, I also appreciate that you kept it to the point without creating further questions to complicate that which is not complicated. Thanks again. Will check out some out your other work.
J Brent Masters - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 24
Altijd: 6,452
