Ga door naar hoofdinhoud
HP Folio 13t-1000 Heatsink Replacement
Wat je nodig hebt
    1. HP Folio 13t-1000 Heatsink Replacement, Keyboard: stap 1, afbeelding 1 van 2 HP Folio 13t-1000 Heatsink Replacement, Keyboard: stap 1, afbeelding 2 van 2
      • Use an antistatic wrist wrap, or periodically touch unpainted metal to minimize the risk of damaging the laptop by electrostatic shock.
      • Use a PH1 screw head to remove the 16, 6mm screws from the bottom case housing of the laptop.
      Vraag FixBot
      Voeg opmerking toe
    2. HP Folio 13t-1000 Heatsink Replacement: stap 2, afbeelding 1 van 3 HP Folio 13t-1000 Heatsink Replacement: stap 2, afbeelding 2 van 3 HP Folio 13t-1000 Heatsink Replacement: stap 2, afbeelding 3 van 3
      • This step requires unlocking the very fragile plastic clips along the frame; take care not to damage them.
      • Slide the spudger with a twisting motion along the entire perimeter of the laptop until the top cover is separated from the frame of the device.
      Vraag FixBot
      Voeg opmerking toe
    3. HP Folio 13t-1000 Heatsink Replacement: stap 3, afbeelding 1 van 1
      • Using the flat portion of the plastic spudger, push the corner of the black surface until the first clip unlocks.
      • The top right corner of the keyboard should now be sticking out slightly.
      • Repeat the same process for the top left corner.
      Vraag FixBot
      Voeg opmerking toe
    4. HP Folio 13t-1000 Heatsink Replacement: stap 4, afbeelding 1 van 2 HP Folio 13t-1000 Heatsink Replacement: stap 4, afbeelding 2 van 2
      • Slide the keyboard up and towards the screen just enough to separate the keyboard from the top cover.
      Vraag FixBot
      Voeg opmerking toe
    5. HP Folio 13t-1000 Heatsink Replacement: stap 5, afbeelding 1 van 3 HP Folio 13t-1000 Heatsink Replacement: stap 5, afbeelding 2 van 3 HP Folio 13t-1000 Heatsink Replacement: stap 5, afbeelding 3 van 3
      • To unlock the clamps connected to the motherboard, use your fingers or insert the pointed edge of the spudger between the first clamp and the cable.
      • Repeat the same process for the second clamp.
      Vraag FixBot
      Voeg opmerking toe
    6. HP Folio 13t-1000 Heatsink Replacement: stap 6, afbeelding 1 van 3 HP Folio 13t-1000 Heatsink Replacement: stap 6, afbeelding 2 van 3 HP Folio 13t-1000 Heatsink Replacement: stap 6, afbeelding 3 van 3
      • Remove the keyboard from the laptop.
      Vraag FixBot
      Voeg opmerking toe
    1. HP Folio 13t-1000 Heatsink Replacement, Top Hardware Cover: stap 7, afbeelding 1 van 3 HP Folio 13t-1000 Heatsink Replacement, Top Hardware Cover: stap 7, afbeelding 2 van 3 HP Folio 13t-1000 Heatsink Replacement, Top Hardware Cover: stap 7, afbeelding 3 van 3
      • Place your finger between one of the plastic clamps and the cable and apply a slight leveraging force until the clamp pops up.
      • Do the same for the second connection.
      Vraag FixBot
      Voeg opmerking toe
    2. HP Folio 13t-1000 Heatsink Replacement: stap 8, afbeelding 1 van 2 HP Folio 13t-1000 Heatsink Replacement: stap 8, afbeelding 2 van 2
      • Remove the top hardware cover.
      Vraag FixBot
      Voeg opmerking toe
    1. HP Folio 13t-1000 Heatsink Replacement, Heat Sink: stap 9, afbeelding 1 van 2 HP Folio 13t-1000 Heatsink Replacement, Heat Sink: stap 9, afbeelding 2 van 2
      • Use a PH1 screw head to take out the four, 2mm screws.
      Vraag FixBot
      Voeg opmerking toe
    2. HP Folio 13t-1000 Heatsink Replacement: stap 10, afbeelding 1 van 3 HP Folio 13t-1000 Heatsink Replacement: stap 10, afbeelding 2 van 3 HP Folio 13t-1000 Heatsink Replacement: stap 10, afbeelding 3 van 3
      • Remove the heatsink with you fingers and replace it with a new heatsink.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Cody Badchkam
112 Reputatie
4 handleidingen geschreven
USF Tampa, Team 1-2, Cagle Fall 2016 Lid van USF Tampa, Team 1-2, Cagle Fall 2016
USFT-CAGLE-F16S1G2
4 Leden
77 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 36
Altijd: 575
