Ga door naar hoofdinhoud
HP Folio 13t-1000 Audio Speakers Replacement
Wat je nodig hebt
  1. HP Folio 13t-1000 Audio Speakers Replacement, Keyboard: stap 1, afbeelding 1 van 2 HP Folio 13t-1000 Audio Speakers Replacement, Keyboard: stap 1, afbeelding 2 van 2
    • Use an antistatic wrist wrap, or periodically touch unpainted metal to minimize the risk of damaging the laptop by electrostatic shock.
    • Use a PH1 screw head to remove the 16, 6mm screws from the bottom case housing of the laptop.
  2. HP Folio 13t-1000 Audio Speakers Replacement: stap 2, afbeelding 1 van 3 HP Folio 13t-1000 Audio Speakers Replacement: stap 2, afbeelding 2 van 3 HP Folio 13t-1000 Audio Speakers Replacement: stap 2, afbeelding 3 van 3
    • This step requires unlocking the very fragile plastic clips along the frame; take care not to damage them.
    • Slide the spudger with a twisting motion along the entire perimeter of the laptop until the top cover is separated from the frame of the device.
  3. HP Folio 13t-1000 Audio Speakers Replacement: stap 3, afbeelding 1 van 1
    • Using the flat portion of the plastic spudger, push the corner of the black surface until the first clip unlocks.
    • The top right corner of the keyboard should now be sticking out slightly.
    • Repeat the same process for the top left corner.
  4. HP Folio 13t-1000 Audio Speakers Replacement: stap 4, afbeelding 1 van 2 HP Folio 13t-1000 Audio Speakers Replacement: stap 4, afbeelding 2 van 2
    • Slide the keyboard up and towards the screen just enough to separate the keyboard from the top cover.
  5. HP Folio 13t-1000 Audio Speakers Replacement: stap 5, afbeelding 1 van 3 HP Folio 13t-1000 Audio Speakers Replacement: stap 5, afbeelding 2 van 3 HP Folio 13t-1000 Audio Speakers Replacement: stap 5, afbeelding 3 van 3
    • To unlock the clamps connected to the motherboard, use your fingers or insert the pointed edge of the spudger between the first clamp and the cable.
    • Repeat the same process for the second clamp.
  6. HP Folio 13t-1000 Audio Speakers Replacement: stap 6, afbeelding 1 van 3 HP Folio 13t-1000 Audio Speakers Replacement: stap 6, afbeelding 2 van 3 HP Folio 13t-1000 Audio Speakers Replacement: stap 6, afbeelding 3 van 3
    • Remove the keyboard from the laptop.
  7. HP Folio 13t-1000 Audio Speakers Replacement, Top Hardware Cover: stap 7, afbeelding 1 van 3 HP Folio 13t-1000 Audio Speakers Replacement, Top Hardware Cover: stap 7, afbeelding 2 van 3 HP Folio 13t-1000 Audio Speakers Replacement, Top Hardware Cover: stap 7, afbeelding 3 van 3
    • Place your finger between one of the plastic clamps and the cable and apply a slight leveraging force until the clamp pops up.
    • Do the same for the second connection.
  8. HP Folio 13t-1000 Audio Speakers Replacement: stap 8, afbeelding 1 van 2 HP Folio 13t-1000 Audio Speakers Replacement: stap 8, afbeelding 2 van 2
    • Remove the top hardware cover.
  9. HP Folio 13t-1000 Audio Speakers Replacement, Audio Speakers: stap 9, afbeelding 1 van 1
    • For the left speaker, use the PH1 screw head to remove the 2 screws.
  10. HP Folio 13t-1000 Audio Speakers Replacement: stap 10, afbeelding 1 van 2 HP Folio 13t-1000 Audio Speakers Replacement: stap 10, afbeelding 2 van 2
    • Carefully unplug the connection to the motherboard using your finger or the nylon spudger.
  11. HP Folio 13t-1000 Audio Speakers Replacement: stap 11, afbeelding 1 van 3 HP Folio 13t-1000 Audio Speakers Replacement: stap 11, afbeelding 2 van 3 HP Folio 13t-1000 Audio Speakers Replacement: stap 11, afbeelding 3 van 3
    • Carefully remove and replace the left speaker.
  12. HP Folio 13t-1000 Audio Speakers Replacement: stap 12, afbeelding 1 van 1
    • For the right speaker, use the PH1 screw head to remove the 2 screws.
  13. HP Folio 13t-1000 Audio Speakers Replacement: stap 13, afbeelding 1 van 1
    • Move aside the black and white wires that are channeled through the top of the speaker housing using your fingers.
  14. HP Folio 13t-1000 Audio Speakers Replacement: stap 14, afbeelding 1 van 2 HP Folio 13t-1000 Audio Speakers Replacement: stap 14, afbeelding 2 van 2
    • Unplug the connection to the motherboard using your fingers or the nylon spudger.
  15. HP Folio 13t-1000 Audio Speakers Replacement: stap 15, afbeelding 1 van 1
    • Carefully remove and replace the right speaker.
Conclusie
Josh Rollins
131 Reputatie
3 handleidingen geschreven
USF Tampa, Team 1-2, Cagle Fall 2016 Lid van USF Tampa, Team 1-2, Cagle Fall 2016
USFT-CAGLE-F16S1G2
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 278
