Ga door naar hoofdinhoud
HP Envy x360 m6-w103dx Speakers Replacement
Wat je nodig hebt
  1. HP Envy x360 m6-w103dx Speakers Replacement, Keyboard: stap 1, afbeelding 1 van 2 HP Envy x360 m6-w103dx Speakers Replacement, Keyboard: stap 1, afbeelding 2 van 2
    • Before you begin, be sure to power off your laptop.
    • Using an opening pick, remove the 4 rubber feet and 4 screw covers.
  2. HP Envy x360 m6-w103dx Speakers Replacement: stap 2, afbeelding 1 van 2 HP Envy x360 m6-w103dx Speakers Replacement: stap 2, afbeelding 2 van 2
    • Unscrew the twelve 6 mm screws from the bottom of the laptop using a Phillips #0 screwdriver.
  3. HP Envy x360 m6-w103dx Speakers Replacement: stap 3, afbeelding 1 van 3 HP Envy x360 m6-w103dx Speakers Replacement: stap 3, afbeelding 2 van 3 HP Envy x360 m6-w103dx Speakers Replacement: stap 3, afbeelding 3 van 3
    • Open the laptop carefully, with the keyboard face up.
    • Pry around the outside of the keyboard with the plastic opening tool until the keyboard can be lifted slightly.
    • When lifting the keyboard do not pull too hard. There are cables that must be disconnected before the keyboard can be removed.
  4. HP Envy x360 m6-w103dx Speakers Replacement: stap 4, afbeelding 1 van 3 HP Envy x360 m6-w103dx Speakers Replacement: stap 4, afbeelding 2 van 3 HP Envy x360 m6-w103dx Speakers Replacement: stap 4, afbeelding 3 van 3
    • Lift the keyboard until you can see the cables connected to the motherboard.
    • Gently lift the tab on each ZIF connector that connects each cable to the motherboard using a spudger. Once each tab is flipped up, the corresponding ribbon cable will come out easily.
    • Detach the keyboard.
  5. HP Envy x360 m6-w103dx Speakers Replacement, Speakers: stap 5, afbeelding 1 van 1
    • Disconnect the connector on the left speaker by gently pulling on each side of the connector.
    • Do not pull directly on the wires.
  6. HP Envy x360 m6-w103dx Speakers Replacement: stap 6, afbeelding 1 van 2 HP Envy x360 m6-w103dx Speakers Replacement: stap 6, afbeelding 2 van 2
    • Unscrew the three 6mm screws using a #00 Phillips screwdriver, one on the right speaker and two on the left speaker.
  7. HP Envy x360 m6-w103dx Speakers Replacement: stap 7, afbeelding 1 van 3 HP Envy x360 m6-w103dx Speakers Replacement: stap 7, afbeelding 2 van 3 HP Envy x360 m6-w103dx Speakers Replacement: stap 7, afbeelding 3 van 3
    • Remove each speaker one at a time.
    • Carefully remove the wire connecting the two speakers, which is tucked under small plastic hooks on the bottom edge of the device.
Conclusie
Steven Ngo
927 Reputatie
7 handleidingen geschreven
Cal Poly, Team S12-G2, Regan Fall 2019 Lid van Cal Poly, Team S12-G2, Regan Fall 2019
CPSU-REGAN-F19S12G2
4 Leden
23 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 22
Altijd: 642
