Ga door naar hoofdinhoud
HP Envy x360 m6-w103dx Motherboard Replacement
Wat je nodig hebt
  1. HP Envy x360 m6-w103dx Motherboard Replacement, Keyboard: stap 1, afbeelding 1 van 2 HP Envy x360 m6-w103dx Motherboard Replacement, Keyboard: stap 1, afbeelding 2 van 2
    • Before you begin, be sure to power off your laptop.
    • Using an opening pick, remove the 4 rubber feet and 4 screw covers.
  2. HP Envy x360 m6-w103dx Motherboard Replacement: stap 2, afbeelding 1 van 2 HP Envy x360 m6-w103dx Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Unscrew the twelve 6 mm screws from the bottom of the laptop using a Phillips #0 screwdriver.
  3. HP Envy x360 m6-w103dx Motherboard Replacement: stap 3, afbeelding 1 van 3 HP Envy x360 m6-w103dx Motherboard Replacement: stap 3, afbeelding 2 van 3 HP Envy x360 m6-w103dx Motherboard Replacement: stap 3, afbeelding 3 van 3
    • Open the laptop carefully, with the keyboard face up.
    • Pry around the outside of the keyboard with the plastic opening tool until the keyboard can be lifted slightly.
    • When lifting the keyboard do not pull too hard. There are cables that must be disconnected before the keyboard can be removed.
  4. HP Envy x360 m6-w103dx Motherboard Replacement: stap 4, afbeelding 1 van 3 HP Envy x360 m6-w103dx Motherboard Replacement: stap 4, afbeelding 2 van 3 HP Envy x360 m6-w103dx Motherboard Replacement: stap 4, afbeelding 3 van 3
    • Lift the keyboard until you can see the cables connected to the motherboard.
    • Gently lift the tab on each ZIF connector that connects each cable to the motherboard using a spudger. Once each tab is flipped up, the corresponding ribbon cable will come out easily.
    • Detach the keyboard.
  5. HP Envy x360 m6-w103dx Motherboard Replacement, Motherboard: stap 5, afbeelding 1 van 1
    • Disconnect the pin head battery connection to remove power from the motherboard.
    • Unscrew the five 4mm screws holding the motherboard in place using a #0 Phillips screwdriver.
    • It's possible the positions of the screws will be different on your board. If the motherboard resists lifting, double-check that all screws have been removed.
  6. HP Envy x360 m6-w103dx Motherboard Replacement: stap 6, afbeelding 1 van 3 HP Envy x360 m6-w103dx Motherboard Replacement: stap 6, afbeelding 2 van 3 HP Envy x360 m6-w103dx Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Remove the five flat ribbon cables by gently lifting the head of the cable up and back.
    • Remove the two remaining multicolored ribbon cables by pulling the white plastic head backwards.
    • Do not pull directly on the wires.
    • If the head of the multicolored ribbon cable doesn't come out, try gently wiggling it side to side as you pull.
  7. HP Envy x360 m6-w103dx Motherboard Replacement: stap 7, afbeelding 1 van 3 HP Envy x360 m6-w103dx Motherboard Replacement: stap 7, afbeelding 2 van 3 HP Envy x360 m6-w103dx Motherboard Replacement: stap 7, afbeelding 3 van 3
    • Lift the motherboard up from the left side at a shallow angle.
    • Gently pull the motherboard to the left and gently wiggle it side to side until the ports on the right side of the board detach from the case.
    • Ensure the laptop is well supported, as the motherboard is a heavy component and removing it may make the laptop off-balance.
Conclusie
Steven Ngo
927 Reputatie
7 handleidingen geschreven
Cal Poly, Team S12-G2, Regan Fall 2019 Lid van Cal Poly, Team S12-G2, Regan Fall 2019
CPSU-REGAN-F19S12G2
4 Leden
23 handleidingen geschreven
2 opmerkingen
Can I Change the graphics card only?
Is there a way to fix only the graphics card?
Frank - Antwoord
I wonder if it’s possible to solder on an M.2 header on that SSD1 spot on the board.
Isaac Zachary - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 26
Altijd: 1,582
