Ga door naar hoofdinhoud
HP Envy x360 m6-aq105dx Back Cover Replacement
Wat je nodig hebt
  1. HP Envy x360 m6-aq105dx Back Cover Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Ground yourself by touching a metal object or surface. This prevents electrical damage to other components in the laptop.
    • Remove the two 7.8 mm screws using the Phillips #0 screwdriver.
    • Remove the six 5.2 mm screws using the Torx T5 screwdriver.
  2. HP Envy x360 m6-aq105dx Back Cover Replacement: stap 2, afbeelding 1 van 1
    • Light to moderate force is required to remove the back cover.
    • Insert the Jimmy in between the frame of the laptop and the removable back cover and remove the back cover from the device.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 9
Altijd: 544
