Ga door naar hoofdinhoud
HP Envy x360 m6-aq105dx Audio Jack Replacement
Wat je nodig hebt
  1. HP Envy x360 m6-aq105dx Audio Jack Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Ground yourself by touching a metal object or surface. This prevents electrical damage to other components in the laptop.
    • Remove the two 7.8 mm screws using the Phillips #0 screwdriver.
    • Remove the six 5.2 mm screws using the Torx T5 screwdriver.
  2. HP Envy x360 m6-aq105dx Audio Jack Replacement: stap 2, afbeelding 1 van 1
    • Light to moderate force is required to remove the back cover.
    • Insert the Jimmy in between the frame of the laptop and the removable back cover and remove the back cover from the device.
  3. HP Envy x360 m6-aq105dx Audio Jack Replacement, Audio Jack: stap 3, afbeelding 1 van 1
    • Attach the grounding bracelet's clip to the frame of the laptop, then put on the grounding bracelet.
    • Remove the two 4.6 mm screws using the Phillips #0 screwdriver.
    • Remove the one 4.4mm screw using the Phillips #0 screwdriver.
    • Remove the one 2.8mm screws securing the audio jack/power button board using the Phillips #0 screwdriver.
  4. HP Envy x360 m6-aq105dx Audio Jack Replacement: stap 4, afbeelding 1 van 2 HP Envy x360 m6-aq105dx Audio Jack Replacement: stap 4, afbeelding 2 van 2
    • Place the blue plastic opening tool on top of the blue data ribbon and under the connector. Lift up on the blue plastic opening tool to open the connector.
    • Remove the blue data ribbon from the audio board.
  5. HP Envy x360 m6-aq105dx Audio Jack Replacement: stap 5, afbeelding 1 van 2 HP Envy x360 m6-aq105dx Audio Jack Replacement: stap 5, afbeelding 2 van 2
    • Remove the audio jack motherboard from the computer.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 338
