Ga door naar hoofdinhoud
HP Envy x360 m6-aq103dx Wireless Module Replacement
Wat je nodig hebt
  1. HP Envy x360 m6-aq103dx Wireless Module Replacement, Bottom Cover: stap 1, afbeelding 1 van 3 HP Envy x360 m6-aq103dx Wireless Module Replacement, Bottom Cover: stap 1, afbeelding 2 van 3 HP Envy x360 m6-aq103dx Wireless Module Replacement, Bottom Cover: stap 1, afbeelding 3 van 3
    • Flip the laptop over to expose the underside.
    • Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
    • The grip pads are tacky, remove slowly to avoid separating the adhesive.
  2. HP Envy x360 m6-aq103dx Wireless Module Replacement: stap 2, afbeelding 1 van 1
    • Remove the two 8 mm Phillips Head screws that were under the grip pads using a Phillip's Head 1 Screwdriver.
  3. HP Envy x360 m6-aq103dx Wireless Module Replacement: stap 3, afbeelding 1 van 1
    • Remove the six 5 mm Torx screws using a T5 Torx Screwdriver.
  4. HP Envy x360 m6-aq103dx Wireless Module Replacement: stap 4, afbeelding 1 van 3 HP Envy x360 m6-aq103dx Wireless Module Replacement: stap 4, afbeelding 2 van 3 HP Envy x360 m6-aq103dx Wireless Module Replacement: stap 4, afbeelding 3 van 3
    • Use the nylon spudger to pop off the bottom cover by inserting it into the heat vent and twisting to the left or right.
    • You may hear a slight clicking or popping, but that is normal.
  5. HP Envy x360 m6-aq103dx Wireless Module Replacement, Battery: stap 5, afbeelding 1 van 2 HP Envy x360 m6-aq103dx Wireless Module Replacement, Battery: stap 5, afbeelding 2 van 2
    • Use the Phillips Head 1 Screwdriver to remove the six 4 mm screws.
  6. HP Envy x360 m6-aq103dx Wireless Module Replacement: stap 6, afbeelding 1 van 3 HP Envy x360 m6-aq103dx Wireless Module Replacement: stap 6, afbeelding 2 van 3 HP Envy x360 m6-aq103dx Wireless Module Replacement: stap 6, afbeelding 3 van 3
    • Disconnect the battery port from the motherboard by gently lifting it on both sides with the plastic opening tool.
    • Lift up the port with the tool.
  7. HP Envy x360 m6-aq103dx Wireless Module Replacement: stap 7, afbeelding 1 van 3 HP Envy x360 m6-aq103dx Wireless Module Replacement: stap 7, afbeelding 2 van 3 HP Envy x360 m6-aq103dx Wireless Module Replacement: stap 7, afbeelding 3 van 3
    • Lift the battery out of the laptop with your hands.
  8. HP Envy x360 m6-aq103dx Wireless Module Replacement, Intel Wireless Module: stap 8, afbeelding 1 van 3 HP Envy x360 m6-aq103dx Wireless Module Replacement, Intel Wireless Module: stap 8, afbeelding 2 van 3 HP Envy x360 m6-aq103dx Wireless Module Replacement, Intel Wireless Module: stap 8, afbeelding 3 van 3
    • Remove the two antenna cables connected to the wireless module by wedging the small plastic opening tool between the cables and the wireless module and lifting up.
  9. HP Envy x360 m6-aq103dx Wireless Module Replacement: stap 9, afbeelding 1 van 1
    • Remove the 3.5 mm Phillips Head screw with the Phillip Head 1 screwdriver.
  10. HP Envy x360 m6-aq103dx Wireless Module Replacement: stap 10, afbeelding 1 van 3 HP Envy x360 m6-aq103dx Wireless Module Replacement: stap 10, afbeelding 2 van 3 HP Envy x360 m6-aq103dx Wireless Module Replacement: stap 10, afbeelding 3 van 3
    • Slide the wireless module towards the back of the computer to remove it.
Conclusie
Joey Chen
316 Reputatie
2 handleidingen geschreven
Cal Poly, Team S4-G3, Livingston Fall 2017 Lid van Cal Poly, Team S4-G3, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G3
4 Leden
9 handleidingen geschreven
Één opmerking
@jchen202 Just curious, what is the Battery Wattage of this HP Envy? I noticed your guide contains a glimpse of the DC IN CONNECTOR , which seems to be identical to my HP ENVY X360 - 15M-BP112DX. How idid your repairs turn out? If possible, would you be able to provide a picture of the DC IN Connector?
Al N - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 1,032
