Ga door naar hoofdinhoud
HP Envy x360 m6-aq103dx RAM Replacement
Wat je nodig hebt
  1. HP Envy x360 m6-aq103dx RAM Replacement, Bottom Cover: stap 1, afbeelding 1 van 3 HP Envy x360 m6-aq103dx RAM Replacement, Bottom Cover: stap 1, afbeelding 2 van 3 HP Envy x360 m6-aq103dx RAM Replacement, Bottom Cover: stap 1, afbeelding 3 van 3
    • Flip the laptop over to expose the underside.
    • Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
    • The grip pads are tacky, remove slowly to avoid separating the adhesive.
  2. HP Envy x360 m6-aq103dx RAM Replacement: stap 2, afbeelding 1 van 1
    • Remove the two 8 mm Phillips Head screws that were under the grip pads using a Phillip's Head 1 Screwdriver.
  3. HP Envy x360 m6-aq103dx RAM Replacement: stap 3, afbeelding 1 van 1
    • Remove the six 5 mm Torx screws using a T5 Torx Screwdriver.
  4. HP Envy x360 m6-aq103dx RAM Replacement: stap 4, afbeelding 1 van 3 HP Envy x360 m6-aq103dx RAM Replacement: stap 4, afbeelding 2 van 3 HP Envy x360 m6-aq103dx RAM Replacement: stap 4, afbeelding 3 van 3
    • Use the nylon spudger to pop off the bottom cover by inserting it into the heat vent and twisting to the left or right.
    • You may hear a slight clicking or popping, but that is normal.
  5. HP Envy x360 m6-aq103dx RAM Replacement, Battery: stap 5, afbeelding 1 van 2 HP Envy x360 m6-aq103dx RAM Replacement, Battery: stap 5, afbeelding 2 van 2
    • Use the Phillips Head 1 Screwdriver to remove the six 4 mm screws.
  6. HP Envy x360 m6-aq103dx RAM Replacement: stap 6, afbeelding 1 van 3 HP Envy x360 m6-aq103dx RAM Replacement: stap 6, afbeelding 2 van 3 HP Envy x360 m6-aq103dx RAM Replacement: stap 6, afbeelding 3 van 3
    • Disconnect the battery port from the motherboard by gently lifting it on both sides with the plastic opening tool.
    • Lift up the port with the tool.
  7. HP Envy x360 m6-aq103dx RAM Replacement: stap 7, afbeelding 1 van 3 HP Envy x360 m6-aq103dx RAM Replacement: stap 7, afbeelding 2 van 3 HP Envy x360 m6-aq103dx RAM Replacement: stap 7, afbeelding 3 van 3
    • Lift the battery out of the laptop with your hands.
  8. HP Envy x360 m6-aq103dx RAM Replacement, RAM: stap 8, afbeelding 1 van 2 HP Envy x360 m6-aq103dx RAM Replacement, RAM: stap 8, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Anti-Static Wrist Strap
    $7.95
    Koop
  9. HP Envy x360 m6-aq103dx RAM Replacement: stap 9, afbeelding 1 van 3 HP Envy x360 m6-aq103dx RAM Replacement: stap 9, afbeelding 2 van 3 HP Envy x360 m6-aq103dx RAM Replacement: stap 9, afbeelding 3 van 3
    • Pull the two outer pins on either side of the ram chip outward with your hands.
    • The ram chips should pop up.
    • Do this for both chips.
  10. HP Envy x360 m6-aq103dx RAM Replacement: stap 10, afbeelding 1 van 3 HP Envy x360 m6-aq103dx RAM Replacement: stap 10, afbeelding 2 van 3 HP Envy x360 m6-aq103dx RAM Replacement: stap 10, afbeelding 3 van 3
    • Remove the chips one at a time, by sliding them towards the side of the computer they are pointing towards.
Conclusie
Joey Chen
316 Reputatie
2 handleidingen geschreven
Cal Poly, Team S4-G3, Livingston Fall 2017 Lid van Cal Poly, Team S4-G3, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G3
4 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 21
Altijd: 4,021
