Inleiding
Are you unhappy with the performance of your HP Envy x360 m6-aq103dx? If so, here is the guide to replace your motherboard. With just a few tools, you can replace your HP Envy x360 m6-aq103dx's motherboard today.
Wat je nodig hebt
Flip the laptop over to expose the underside.
Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
Gereedschap gebruikt in deze stap:Anti-Static Wrist Strap$7.95
Make sure you are wearing an anti-static wrist strap.
Remove the four screws from the blue board that contains the headphone jack using the Phillips head 1 screwdriver (one 4 mm black screw, one 3 mm black screw, and two 4.5 mm silver screws).
Remove the two antenna cables connected to the wireless module by wedging the small plastic opening tool between the cables and the wireless module and lifting up.
Disconnect the ribbon cable with the purple tag by flipping the black tab with the plastic opening tool.
Disconnect the ribbon cable by gently pulling it away from the connector with your fingers.
Remove the ram’s metal cover with your hand.
Use the small plastic opening tool to disconnect the port attached to the white ribbon cable with purple tips.
Press the tool to the top of the tip of the cable and pull it outwards.
Press the tool to the side of the tip of the cable and slide it outwards.
Use your hand to lift the cable up and out of the way.
Use the small plastic opening tool to disconnect the port attached to the blue ribbon cable with a black stripe.
Use the small plastic opening tool to disconnect the port attached to the golden brown ribbon cable with the yellow underside.
6 andere personen hebben deze handleiding voltooid.
4 opmerkingen
how to replace the keyboard?
need a solder gun?
What are the newer motherboards I can upgrade this laptop with ? please advise.
