Ga door naar hoofdinhoud
HP Envy x360 m6-aq103dx Hard drive Replacement
Wat je nodig hebt
  1. HP Envy x360 m6-aq103dx Hard drive Replacement, Bottom Cover: stap 1, afbeelding 1 van 3 HP Envy x360 m6-aq103dx Hard drive Replacement, Bottom Cover: stap 1, afbeelding 2 van 3 HP Envy x360 m6-aq103dx Hard drive Replacement, Bottom Cover: stap 1, afbeelding 3 van 3
    • Flip the laptop over to expose the underside.
    • Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
    • The grip pads are tacky, remove slowly to avoid separating the adhesive.
  2. HP Envy x360 m6-aq103dx Hard drive Replacement: stap 2, afbeelding 1 van 1
    • Remove the two 8 mm Phillips Head screws that were under the grip pads using a Phillip's Head 1 Screwdriver.
  3. HP Envy x360 m6-aq103dx Hard drive Replacement: stap 3, afbeelding 1 van 1
    • Remove the six 5 mm Torx screws using a T5 Torx Screwdriver.
  4. HP Envy x360 m6-aq103dx Hard drive Replacement: stap 4, afbeelding 1 van 3 HP Envy x360 m6-aq103dx Hard drive Replacement: stap 4, afbeelding 2 van 3 HP Envy x360 m6-aq103dx Hard drive Replacement: stap 4, afbeelding 3 van 3
    • Use the nylon spudger to pop off the bottom cover by inserting it into the heat vent and twisting to the left or right.
    • You may hear a slight clicking or popping, but that is normal.
  5. HP Envy x360 m6-aq103dx Hard drive Replacement, Hard Drive: stap 5, afbeelding 1 van 3 HP Envy x360 m6-aq103dx Hard drive Replacement, Hard Drive: stap 5, afbeelding 2 van 3 HP Envy x360 m6-aq103dx Hard drive Replacement, Hard Drive: stap 5, afbeelding 3 van 3
    • Disconnect the ribbon cable with the purple tag by flipping the black tab with the plastic opening tool.
    • Disconnect the ribbon cable by gently pulling it away from the connector with your fingers.
  6. HP Envy x360 m6-aq103dx Hard drive Replacement: stap 6, afbeelding 1 van 3 HP Envy x360 m6-aq103dx Hard drive Replacement: stap 6, afbeelding 2 van 3 HP Envy x360 m6-aq103dx Hard drive Replacement: stap 6, afbeelding 3 van 3
    • Remove the two Phillips head screws (5 mm) using the Phillip's head #1 screwdriver.
    • Use your hands to lift the hard drive up and remove it.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Jordan Eremeyeff
597 Reputatie
3 handleidingen geschreven
Cal Poly, Team S4-G3, Livingston Fall 2017 Lid van Cal Poly, Team S4-G3, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G3
4 Leden
9 handleidingen geschreven
Één opmerking
Great guide. Only thing i did different was not removing the ribbon cable. It’s not necessary. Just unscrew the hard drive enclosure and you’ll have plenty of room to disconnect the sata connector plugged in to the drive.
Ron H - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 26
Altijd: 7,123
